rear door folding table - Defender Source
Old November 22nd, 2008, 09:48 PM
Just finished and I love it. 12" deep, made of 1/2" marine Starboard. Held up by a marine cabinet rotating latch. Hinged by stainless piano hinge. suspended by 2 stainless braided and sleeved cables that I salvaged from a dog yard chain. I'm going to add a reading light and fire extinguisher to it.
FYI. Also mounted at a slight angle since the door is not level on full open. I used a level to confirm. Mounted hight is just about right for desk height with a camp chair.
So few examples I could find on the internet, that I thought I would share for posterity.
Name:	safari door front.jpg
ID:	16520   Click image for larger version
Name:	safari door angle.jpg
Old November 23rd, 2008, 01:24 PM
Neat !
Old November 24th, 2008, 11:18 PM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
That is pretty cool. Nice job! By the way how the hell did you get the door to stay open for the picture
Old November 24th, 2008, 11:58 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
If your door doesn't stay open you may have a worn out door check. Once the wheel passes the little bar it should stay in that position, if it doesn't, the bar may be worn out. I think you can buy them pretty cheap from the dealer, otherwise someone else here just shoved a penny between the door and the bar to create more pressure. Check the tech articles under "Keep that door open".
Old November 25th, 2008, 01:53 AM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
Thanks Andrew, I know how to fix it, it is just one of those things that I just get pleasure out of watching the wife try to hold it open while trying to remove something out of the back. That is just wrong isn't it.
Old November 25th, 2008, 01:58 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Haha, I like it...sounds like something I would do!
Old November 25th, 2008, 08:49 PM
Yes it is!
Old December 12th, 2008, 08:43 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Mark -- can you post some detailed photos of how you constructed the table? As I have the panel on its way, I"m starting to consider how to configure it. I'd like to figure out how to get a table, fire extinguisher and first aid kit onto it eventually.
Thanks, and thanks again for all of the upfront work on the panel,
Tony
Old March 25th, 2009, 08:32 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
94 D90 Red HalfCab #741
Neat table. I am planning something similar except with a coleman cook top stove. Open the door, hinge the stove down, hook up the propane and cook some burgers!! have some good times.
Old March 27th, 2009, 01:20 AM
I was seriously considering the mounted stove thing, but when I was vetting the idea, I got inside the jump seat, closed the door, and realized that the stove stuck out to far for a passenger in the rear jump seat. since having 2 jump seats on one side of my rear area was a requirement, I decided to go with the table. I can put a stove on the table, or use the table as an field desk. more multipurpose that way. Plus, if you ever have anything big and heavy in the back, unless it's well secured, that stove is going to take a beating.
Tony,
Sorry for the delay. I'm training to go to Iraq, and nowhere near my Rover right now.
door, rear door
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear door table! TwisteD90 Defender Technical Discussions 10 April 5th, 2004 11:43 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
