Rear Corner Guards for D90 - Page 2 - Defender Source
Old May 13th, 2016, 10:11 AM
Originally Posted by 1of40 View Post
Rattle-can for non-mall crawler versions would be a nice option.
Galv is best.
Old May 13th, 2016, 10:53 AM
madcowdungbeetle
Carter
With regards to the finish. I will only ship out powder freshly powder coated parts. I realize my stuff is not the cheapest, and because of that I want to ensure that the final product and finish is done to the highest possible level of quality.
If someone decides they would rather strip the powder coating and rattle can the finish, they are free to do that.
Should they decide they would like to strip the powder coating and galvanize it, they are free to do that too.
Old May 13th, 2016, 11:48 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
That makes sense to me.
Old May 13th, 2016, 01:05 PM
Raquen
Matthew
none
Any reason these wouldn't work on a 110?
Old May 13th, 2016, 01:58 PM
madcowdungbeetle
Carter
I have seen other 90 corner guards fitted on 110's before. I have not fit these to a 110 though so I cannot comment as to how they fit/look.
Old May 13th, 2016, 03:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Umm... the length difference is significant...
Rent my
Old May 13th, 2016, 06:05 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
Im interested when you can get the ones worked for the NAS step bumper
Old May 13th, 2016, 06:11 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Same here. Will you have something that works with a NAS step bumper & swing away tire carrier??
Rent my
Old May 13th, 2016, 06:58 PM
madcowdungbeetle
Carter
I currently have no plans to make ones that will work with an NAS bumper.
I will have RCG's that are compatable with the NAS ST tire carriers soon.
Old May 14th, 2016, 11:34 AM
Raquen
Matthew
none
While yes a 110 is 20 inches longer then a 90 I was ask if anyone knew why these would not fit. That answer doesn't really see any light on why they would not work.
Another question, it looks like with the two securing points one is on the rear crossmember supply good support but the other looks to go into the rear panel. Does that tap into a reinforced part if the body?
Old May 4th, 2017, 10:38 AM
madcowdungbeetle
Carter
So if anyone with a SW90 has any interest in these, I will cut you a hell of a deal for a a set of these in return for some good hi-res pictures with them installed on their truck. Like a nice set of pics taken with a DSLR camera or something I can use on my Instagram and new website.
Unfortunately my personal 90 is less than photogenic, and I'd like to free up some cash to have more dies machined for the never ending aluminum dash project: http://www.defendersource.com/forum/...cia-68934.html
Old May 4th, 2017, 11:20 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Oh man I am down for one of those.
Old May 4th, 2017, 11:59 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I have a station wagon.. shoot me a PM with your number
good luck with your search
Old May 4th, 2017, 01:25 PM
madcowdungbeetle
Carter
Shot you PM Ron
Old May 4th, 2017, 02:44 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
No ST love?
Old May 7th, 2017, 03:23 PM
madcowdungbeetle
Carter
Originally Posted by D90Overkill View Post
No ST love?
They're coming...
I may tweak the mounting a bit, but they're essentially done. I just got so many projects going right now... lotsa of stuff for the 110 guys in the works too.
Old May 7th, 2017, 06:30 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Not sure if you have this covered? as I see what looks like a hinge on the R/H side, but Mantic spare wheel carriers use the last set of bolt holes.
I had to shorten the Terrafirma unit to suit.
Cheers
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 8th, 2017, 04:19 PM
madcowdungbeetle
Carter
Cheers
These were designed to work with the NAS ST carrier. I have no experience with the Mantec units, and it looks at though the Mantec will not work with my RCG's.
90, d90, guards
Looking for a D90 to test fit Rear Corner Guards madcowdungbeetle Wanted 6 October 6th, 2015 01:21 PM
Safarigard rear corner guards Roverdoc For Sale - Parts 5 March 27th, 2013 05:11 PM
Buffer between corner guards & 2" receiver on rear crossmember nathanwind Defender Technical Discussions 3 February 13th, 2013 01:30 AM
Rear corner guards Brewie212 Smaller Projects 2 November 9th, 2012 09:23 PM
Wanted: Rear corner guards. PCRover Wanted 13 August 27th, 2007 12:00 PM
