Radiator? for a 4.2L and Auto Trans into a D110 - Defender Source
Old November 4th, 2014, 11:02 PM
RhinoRover's Avatar
RhinoRover
Andy
1986 D110
Is there a radiator in any of the model year Defenders that will accommodate all of the cooling lines from a 4.2L RRC engine and automatic transmission? Wanting to install into the stock location of my '86 D110 without heavy modification. I heard that a 1997 or newer Defender radiat. might work. I also need to consider the future installation of the A/C radiator and fans from the RRC too, but not necessary.
Thanks!
Old November 4th, 2014, 11:45 PM
No defender had a Trans cooler in the radiator. You need the porcupine looking one off a 97 D90 (might be the same as an RRC/D1, I don't know). Do you have a 93-94 4.2 or a 95 4.2? The oil cooler lines are different, although the NAS defender radiators are all the same except that early 94 and NAS 110 had removable fittings (maybe they ran later, not sure)
If you have a 93/94, I would just not run the oil cooler lines.
Old November 5th, 2014, 01:11 AM
On my 3.9 out of my dead disco I used a radiator out if a 95 stick and added a Hayden cooler for transmission cooling.
Old November 5th, 2014, 12:42 PM
LRover's Avatar
LRover
J. Michael McCaig
I've had not one problem using the stock V8 radiator in my 110 with the 4.6. Even while towing my farm tractor on my car trailer in the summer it would keep it in the safe zone. I would make sure your stock radiator is in good shape (along with the rest of the cooling system) and install an external transmission cooler.
Old November 8th, 2014, 09:29 AM
Radiator from a v8 defender will be fine. A 4.2 is simply a stroked 3.9. The 97 d90 trans cooler isn't the hair brush looking one but rather a rectangular radiator looking one. I did a 110 conversion using all factory correct 97 NAS 90 bits purchased from Rovers North and would recommend that option. I have also used the hair brush looking one from RRC's and disco's on two auto conversions now and there will need to be a spacer on one end of that cooler as the brackets do not expand out far enough to reach the insides for the front wings. I use a small piece of azek as its easily worked with and inert.
Classic or disco cooling lines will require modification to work, the factory correct lines for a 97 are still available.
Old November 8th, 2014, 09:35 AM
the rover shop
shayne young
Or you could just take the radiators to an old school radiator shop and he can put the left side tank onto the defender radiator and rod it out and flow test it at the same time..shouldn't be more that $100... Job done
Old November 8th, 2014, 10:09 AM
What radiator are you suggesting would he be taking the trans cooler from ? Range rover classics, and disco's, and defenders have external coolers.
Old November 8th, 2014, 10:16 AM
the rover shop
shayne young
I will check the rads I have laying around but you could take the right side tank off a classic and install it on the left side...I wanna say I looked into this before and didn't see a reason why it couldn't be done..the 2 small ports are easily blocked at the same time as the rad shop does his thing..or install a nifty little drain tap there (top right tubes would be bottom left now..)
Old November 8th, 2014, 11:05 AM
I haven't looked at one in a long time, but I seem to remember that they also have a cooler built into the radiator.
Old November 8th, 2014, 11:16 AM
the rover shop
shayne young
Correct..the range rover classic rad I have here (or maybe disco1) has a cooler in each side and that is what I was recalling.the left one looks to be a little wider than one on a defender but only by about half an inch or so. I took a look at a defender with the rad installed and I think there is enough room to do it..pic attached of rad I was referring to..
Old November 8th, 2014, 11:18 AM
the rover shop
shayne young
Crappy pic but definitely one each side..mounting tabs on sides are just sweat on so can easily be removed..defender mounting plates are top and bottom horizontal tank to tank tie ins..
Old November 8th, 2014, 11:20 AM
Classics ran both.
I wouldn't/don't run atf through a radiator . Trans fluid cooks/ burns/breaks down and makes varnish @ just above 200 degree's which is normal operating temp for an engine, it seems like a very poor idea to me. Recollection is that auto trans fluid temps sub 180 degree's are what is reccomended
Old November 8th, 2014, 11:24 AM
A RRC radiator won't fit in a Defender, its just a little bit too wide.
Old November 8th, 2014, 11:26 AM
the rover shop
shayne young
Sorry Doug..d1 and classics have them...right side of rad is engine oil cooler..tranny fluid runs through the left side AND the wire brush looking thingy
------ Follow up post added November 8th, 2014 11:26 AM ------
Yes, but the end caps do onto the shorter defender core..
Old November 8th, 2014, 11:31 AM
the rover shop
shayne young
Rad out of 1997 disco 1..
Old November 8th, 2014, 11:33 AM
the rover shop
shayne young
The top line goes to the brush cooler in front of the radiator and then to the trans but the bottom line goes straight back to the trans..
Old November 8th, 2014, 11:44 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I can tell you from bad experience that any oil cooler lines running through the radiator is a bad design.
A few years back, going to work at 4AM, when I still had the V8 in the Disco, the radiator fractured at the transmission cooling line. The system never showed externals warnings there was a problem. Temperature stayed constant. No leaking because the breach was internal.
The transmission started shifting strangely. Very smooth for what I was accustom to. I checked the fluid when I got to work. It was milky.
During tear down we found coolant in the transmission and the radiator half empty.
My advise, keep the oil cooling lines separate from the radiator.
Black Rhino Lives Matter
Old November 8th, 2014, 11:51 AM
Several manufacturers have come to the same conclusion. I think the original thought process was that since the engines warm up quickly running the fluid through the rad tank would warm it and make for smoother shifts with more viscous fluid and smoother driveability in cold weather.
Old November 8th, 2014, 12:02 PM
Yep said that a couple posts back. Pretty sure that was designed as a warmer for cold weather shifts, not a cooler which is why it is just before the trans on the return. Auto trans Defenders did not utilize one. Trying to understand why you are championing installing one on a defender since we all know Atf fluid temp has a direct correlation to torque converter and clutch/trans life.
I thought the original poster was asking what was the simplest/cheapest/best way to do this.
Old November 8th, 2014, 03:19 PM
the rover shop
shayne young
Not championing it..I thought the OP was asking if a radiator one can be fitted.. And lets also keep in mind radiator temps do not run at engine temps..if it does then there is something wrong and your under radiatored.. Most automatic transmissions cars have the tranny fluid running through the radiator..but usually in the bottom of the radiator where the coolant should be coldest..
110, d110, radiator
3.9L V-8 Engine Complete with auto trans and transfer case Coiler For Sale - Parts 5 August 26th, 2014 09:19 AM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
How difficult is it to convert auto trans to manual in a D90? jaherring Defender Technical Discussions 14 June 17th, 2004 02:05 PM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
