Radiator Drain - Defender Source
Old January 7th, 2012, 12:13 PM
Grover's Avatar
Grover
Thumbs up Radiator Drain
It was time to drain and refill my coolant so I added a radiator inline hose drain
http://www.jegs.com/i/JEGS+Performan...51155/10002/-1
to the lower radiator hose.
Install was easy, you need about 3" worth of straight hose, see pix.
Also this location is the lowest part of the hose which helps for draining coolant.
Cheers...
ID:	45753   Click image for larger version
Old January 8th, 2012, 08:33 AM
Nice mod...
Old January 11th, 2012, 12:43 PM
Grover's Avatar
Grover
Woops...I meant to put this in the Smaller Projects section...
Old January 11th, 2012, 12:57 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
looks good!! sounds like a good thing for me to do next!!
Old January 11th, 2012, 03:54 PM
That's TOOOIGHT! On my TODO list.
Old January 11th, 2012, 05:29 PM
Grover's Avatar
Grover
Thumbs up
Yes, it's tight in there...
I had to remove the A/C belt to get the box cutter 90 degrees to the hose...measure 10x cut once...lol
Cheers...
Old January 11th, 2012, 05:43 PM
I meant tight as in awesome.
Old January 11th, 2012, 10:24 PM
Were you able to reinstall the ac belt? Id drain more often but its always a huge mess thanks for sharing this.
Old January 12th, 2012, 08:37 AM
Grover's Avatar
Grover
Thumbs up
Re-installed the A/C belt...
Draining coolant is sooooo easy now...
Old January 12th, 2012, 03:00 PM
Ordered two today thanks for sharing this, I know it will make my life so much easier
Man its clean under your hood. I am assuming you trimmed the stock hose back a little?
Old January 12th, 2012, 04:16 PM
Grover's Avatar
Grover
Thumbs up
Thanks, I try to keep my D clean...
I cut 1" out of the hose to accommodate for the drain.
The drain piece is 3" long, 1" goes into each hose and 1" is exposed as you see in the pix.
I pumped the coolant out before I cut the hose. Only about a cup worth came out of the hose...
Good luck with the install
Cheers...
Old January 12th, 2012, 04:53 PM
psykokid
Jake
1997 Disco
Is the internal opening of the petcock threaded? It's hard to tell from the photos. If it is you could thread a hose barb in there and have a mess free way to drain the coolant.
Old January 12th, 2012, 08:16 PM
Grover's Avatar
Grover
Thumbs up
No, it is not threaded, however, the coolant drains straight down into a funnel...mess free...
Old April 15th, 2012, 10:55 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
For those of you with steering guards, how do you drain without making a mess? Letting it splash all over the guard is not ideal. I'm thinking of making a wide mouth hose & funnel to route it into a container. Any other suggestions?
Old April 15th, 2012, 05:18 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Awesome. I just took a shower in coolant for the third time. Funnel doesn't work and coolant doesn't taste that great either.
Is this drain fitted on the bottom hose? Looks different than mine. Would it fit in the same spot for a 300tdi? I cant tell what location that is. Must be for a V8. For everyone with a 300tdi, is the only option for draining to make a big fat mess? Looking at what I have I would need a T-shaped drain valve.
Old April 15th, 2012, 10:30 PM
Let it fly, just keep the dog out of the shop until you can wash the floor down. Having just gone through this what a PITA.
Old April 16th, 2012, 07:43 AM
Um, well here's another option that requires SCIENCE!
Many of us who have the plastic or brass radiator plug can simply remove it, stick a (clear) siphon hose down to the bottom of the radiator. Create your siphon into a container and let physics take over. No this won't get every last drop of coolant out, but it make less mess.
Old April 16th, 2012, 09:07 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have a super siphon hose that I'll try next time. The problem with the 300tdi rad though is that you can't seem to get very far down into it. Has anyone tried the block drain on a 300tdi? Smaller hole = more control? Just curious how to access it.
Old April 16th, 2012, 12:30 PM
Grover's Avatar
Grover
Mine is a 3.9L V8. The drain can be installed on any motor/hose provided with enough room.
Cheers...
Old April 16th, 2012, 04:11 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Whenever I have a radiator re-cored, I installed a petcock drain at a bottom corner.
That's what I do for those without a drain. I got a long piece of vinyl tubing a 'T' and a cork to fit.
I cut off two sections, fit the 'T', fit the other two pieces to the 'T' and use one of them to start the siphon and then stick the cork in that piece of tubing once the fluid starts to run.
Using this method also lets you only drain as much as needed, for instance, if you're changing a water pump no need to drain as much.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
drain, radiator
