Quick Connects for winch / jumper cables - Defender Source
Old December 10th, 2006, 08:04 PM
trislerjw
JT
97 D-90 ST
I know many of you have already done this but here are some pics to go along.
I went to autozone and bought2 of the 2 ga battery terminal connectors.
ordered Superwinch quick connects from Exp. Exchange.
Bought 4 ga jumper cables while at autozone..
Cut Terminal ens off of battery cable. Cut one set of ends of of jumper cables. Attached each side to Quick connect plugs.
ID:	7635   Click image for larger version
ID:	7637   Click image for larger version
Old December 15th, 2006, 10:14 AM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
what did you do to connect the wires to the grey plugs? When I wired my inverter using the same plugs, I had to take it somewhere to have the wire connectors crimped onto the wires before inserting them into the quick-connect terminals. That may have been 2 ga, I can't remember...
Old December 15th, 2006, 06:51 PM
trislerjw
JT
97 D-90 ST
Plugs
Well, I didnt have a crimper that size, so I took a small sledge and just smashed it in there that way. (careful not to smash too much though) worked fine.
Old January 10th, 2007, 01:26 PM
andyrad
Andy Radlgruber
None.
You can also use a small torch and solder the leads into the connectors. I did that on an old Ford Ranger I used to have. You need a torch because the stranded wire dissipates the heat too fast to ever be able to heat it any other way.
winch
How does everyone route their winch cables JackW Defender Technical Discussions 10 September 12th, 2008 11:15 AM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
jumper cables Craigd Defender Technical Discussions 5 March 4th, 2005 08:50 PM
Quick Nuts - Where to buy them. Matt Klapmust Defender Technical Discussions 5 March 30th, 2004 11:52 AM
