Hi all, just finished installing the carrier and everything appears to be bolted on correctly.
Here is question for other owners...is it normal that it now takes a little more force to open & close the door with the carrier (spare not yet on the carrier). For example, I'm able to keep the door open mid-way, and when I open the door, it won't just swing wide open like before.
Would another Mantec spare carrier owner confirm this is normal?
The range of door motion feels smooth, just takes more effort than before.
I hope that's normal, because mine does the same thing. It isn't a lot of resistance, but it's enough to make the door motion feel more solid and for the door to stay in position instead of just swinging wide open or shutting. I personally like the added resistance and the way the door feels. You can tell the tire carrier is taking weight and reinforcing the door hinges.
I've had mine on for about 20 yrs and it's real easy to move. If your truck is leaves left to right chk that that top is the same. Your checking for bind. I've always used wheel bearing grease on the upper and lower bushings and on the piston. Also check the piston mounting nut by removing the tire so yo can see any movement of that nut. Loosen first. If it does want to go up or down when you open. Then you do have bind and is out of alignment that's all I got.
Thanks, all.
The piston mounting nut (loosened) doesn't really move up or down at range of motion of the arm - piston nut just sits in the middle of the slot/cut out. I am beginning to think it's due to the piston... b/c even with the piston nut loose, the door feels needing more force to open/close.
I will remove the door nut and see if the arm swing is easily or hard by itself... b/c when the brackets were finger tight, the arm swings freely and easy - i push it lightly and it'll swing all the way open.
I think what you are feeling is just the piston that extends when you open it. Mine requires a little more effort then without it. As long as the action is nice and smooth it should be good to go.
No movement up or down on that piston nut is good. Says your in alignment. You mentioned it swung freely by itself with mounting nuts finger tight. That design can be over tightened. Sounds like your almost their though.
One last question.
How tight should I tighten the nut for the piston and the swing arm?
Instructions say pinch the rubber washer, but should I crank down on it, or only tight enough to allow some movement between the piston and swing arm?
I just realized I need to allow weight of the wheel on the swing arm and not necessarily on the door.
Thanks!
Well for me...I removed the rubber grommet and closed the door and tightened it real good and used the double nut method. It rattled all the time if I didn't. I only loosen now to clean and grease the piston from time to time.
Thanks! I got it installed. I tightened, but didn't crank down on the nut on the piston.
I rocked the wheel a bit and the carrier is solid - didn't shake the door much.
I may tighten down that nut at later time.
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
