quarter panel repair feedback - Defender Source
Old December 19th, 2012, 02:50 PM
spartan's Avatar
spartan
Fred
83 D110
I have a simple idea I would like to get feedback on. The quarter panels on my ROW 110 needs some attention. I thought maybe an aluminum patch panel might look alright.
Putting some silicone in between the two pieces would help minimize dirt from accumulating. Pop rivets to hold it on.
ID:	62983   Click image for larger version
Old December 22nd, 2012, 12:14 AM
Well...it looks like it would cover up the problem partially but it certainly isn't a fix.
Have you considered actually cutting out the rot and having a replacement patch welded in place? Or if you cannot weld the aluminum, rivet a supporting panel behind the quarter - not in front of it.
Old December 27th, 2012, 06:55 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
Hi Fred,
I have the same problem. I posted a short film a view weeks back that i found on you tube. It is not that difficult to replace it with a replacement panel. And they are cheap to.
I would not do a patch job it just will corrode more and eat away you defender. Just replace it. You got a nice project going do it right!
just my 2 cents.
Old December 27th, 2012, 10:02 AM
spartan's Avatar
spartan
Fred
83 D110
Originally Posted by Skeena river rover View Post
Hi Fred,
just my 2 cents.
Jeroen, I took your advice and purchased a set from the same place you did. Thanks for the feedback guys.
Old December 27th, 2012, 11:35 AM
Make sure the thick aluminium support behind it is in good shape. If not, weld in a patch there. I had to do that on my series.
Old December 27th, 2012, 09:46 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
I had to replace rear quarter on 90 and instead of pop riviting a new one on I epoxied like the newer cars. Came out good and easy enough to do in garage. Make sure it's straight however or you'll get to do it again with another panel. Just a thought and another option.
Old January 1st, 2013, 01:37 PM
spartan's Avatar
spartan
Fred
83 D110
Attachment 63453
Landan, that looks good. You only get one shot with adhesive.
ac
Quarter Panel Guards for 90s JSQ For Sale - Parts 173 May 4th, 2017 02:47 PM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
Door Panel Repair? boshea Defender Technical Discussions 3 January 17th, 2006 04:13 PM
D-90 right side rear quarter panel needed ember Wanted 0 February 24th, 2005 08:47 PM
D90 Rear Quarter Panel leafsprung For Sale - Parts 4 November 25th, 2003 02:04 AM
