Puma 3rd Row Seat Install - Page 3 - Defender Source
Old June 10th, 2016, 01:24 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Btw - here is a pic of the ribbon/strap and leg. I am still trying to figure out how they attached while in the upright position.
Old June 10th, 2016, 01:59 PM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
Hey, just a disclaimer everyone. I think most of the part numbers are accurate, but I believe I am wrong on the middle row seat belt bracket. My 85' 110 originally had lap belts for the middle row, so there was never an upper mounting position for the new type of seat belt. I called a few places in the UK and they told me that I just need to find a breaker that has the bracket I need. I am not sure of the part number. I have also been told that the older trim around the middle and rear tub seat belts need modified. My master plan is to contact a breaker and buy all of the Land Rover seat belts, seat belt brackets (for the upper attachments), and trim pieces for these. It will cost me a little bit, but at least I will get everything I need. I think it will look better this way. This is what my 110 looks like as of a few days ago. Cheers....
Old June 10th, 2016, 05:53 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Just wraps around the lower leg and is secured with the clip.
Old June 10th, 2016, 05:54 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Forgot the pic
Old June 10th, 2016, 06:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That's the thing - I don't have the clip. Essentially I have 2 female ends.
Old June 10th, 2016, 06:14 PM
n/m..
Old June 10th, 2016, 06:33 PM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
Will dig up some clips for you, Don.
Sal
Old June 10th, 2016, 06:40 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by budzny View Post
Will dig up some clips for you, Don. Sal
Thanks Sal!
Old June 10th, 2016, 07:20 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looks great!
Sounds like you are doing the seat belts the proper way. I am going to use RN belts. I bought one to test and it seems to work well.
And that's the right way to have it for fab work. I have my cage and everything installed and it's a near getting in and out of it!
Old November 28th, 2016, 04:06 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Quick question - has anyone installed this Rear seat-belt to frame tube bracket (pic) to an NAS rear cross member? If so, does it fit ok (given its designed to fit a puma frame)?
Rufus
[QUOTE=Iamkraig;745261]Don,
- Rear seat-belt to frame tube bracket RH EIO500060
LH EIO500070
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old November 30th, 2016, 08:31 AM
Rufus's Avatar
Rufus
Rufus
Bump - I would appreciate intel, if anyone has done this.
Old November 30th, 2016, 11:10 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
frame holes are in the same place,,, puma and NAS
good luck with your search
Old November 30th, 2016, 05:44 PM
Rufus's Avatar
Rufus
Rufus
Thanks Ron. I have read this part may interfere - as it bolts to the rear crossmember near the same place as the NAS SD cage under-tub section
Old December 4th, 2016, 08:35 PM
Rufus's Avatar
Rufus
Rufus
bump
Old December 5th, 2016, 01:50 PM
Rufus's Avatar
Rufus
Rufus
The NAS 90 SD cage under tub support does interfere with the Puma Rear seat-belt to frame tube bracket - both tie into the rear crossmember at the same spot. For that matter the fuel filler hose is in the way as well.
1st pic (my NAS 90 showing SD under tub cage support)
2nd pic (puma Rear seat-belt to frame tube bracket installed on a ROW truck)
Others have installed the puma rear seats in NAS 90s - I would love to learn what you did to support them under the tub & wheel wells.
Thank you very much - any help would be very much appreciated.
Best,
Rufus
ID:	175601   Click image for larger version
Old December 5th, 2016, 02:31 PM
Rufus's Avatar
Rufus
Rufus
disregard the "side show" on the left of my pic...
vice grips found....
Old June 1st, 2017, 09:14 AM
stancey's Avatar
stancey
steven stancey
Does anyone know where this spacer goes? Kvx000020.
Old June 1st, 2017, 10:23 AM
rivermike's Avatar
rivermike
Michael
2008 LHD Tdci 110 Keswick Green
That spacer is for mounting the NAS back bumper , in order to keep the rear crossmember straight when you tighten the bolts.
For LHD Defender restorations and refurbishments
WEBSITE :
EMAIlL :
Current Inventory is listed in my STOCKLIST section
Worldwide shipping is our specialty
Old June 1st, 2017, 12:42 PM
stancey's Avatar
stancey
steven stancey
Gotcha. So, if I don't have a NAS bumper, they are not needed. Thanks
Old June 23rd, 2017, 05:26 PM
rockster57
Peter
2008 90 County Hard Top
You will still need to use those twin tube spacers inside the rear crossmember when you fit the seat belt support tubes EIO500060 and EIO500070. Their purpose is to stop the crossmember deforming when you torque up the fasteners.
By the way, this is a project I'm also undertaking on my 90 hardtop.
Puma middle row install Iamkraig Smaller Projects 18 August 4th, 2016 04:00 PM
Range Rover Classic upper rear hatch and 3rd row seat spaeth For Sale - Parts 9 March 29th, 2016 07:32 PM
FS Puma 3rd row seats Himalaya For Sale - Parts 1 December 22nd, 2015 02:41 PM
Bulk 3rd Row seat buy Himalaya For Sale - Parts 23 March 5th, 2015 04:30 AM
range rover 3rd row install question mountainviewrover Misc. Chit-Chat 6 November 23rd, 2009 08:47 AM
