Problem greasing the front prop shaft - Defender Source
Old September 12th, 2016, 10:41 PM
lithium1330's Avatar
'97 SW NAS 4.6
Can someone give guidance to 2 issues when trying to grease the front prop shaft:
1) there isn't enough room for me to put the grease gun onto the nipple at the u-joint. Do I need to jack up the front of the truck?
2) the nipple on the prop shaft appears to be jammed. I am unable to squeeze the trigger on the grease gun...
Any help/suggestions?
Old September 12th, 2016, 11:19 PM
Put tcase and truck in neutral and roll it forward a few inches for clearance. Use a 6 or 8mm socket to remove the nipple and clean it out.
Grease away!
Old September 12th, 2016, 11:21 PM
Viton's Avatar
Deaf Ember
Smart 4x4
Lift up (jack) 1 front wheel & engage the tranny in Neutral & apply the Emergency brake, this will allow you to turn the prop shaft by turning the tire that is slightly lifted and position the zirk in the best sport to get the grease gun on it. The zirk fittings do freeze up, I usually us something small to push the little ball bearing in the center of the zirk in and out a bit .... maybe a large paper clip end ? Remember to grease the slip joint zirk too.
For best results and U-joint longevity do this every 5,000 miles.
Front prop shaft options seanreaganphoto Defender Technical Discussions 15 June 29th, 2015 09:11 AM
H/D double cardon D90 front prop(drive) shaft Landy_Andy For Sale - Parts 5 June 18th, 2013 09:38 AM
Greasing Defender, only the 6 fittings on the driveshafts? hillstrubl Defender Technical Discussions 5 June 7th, 2010 08:34 PM
DII Front Prop Shaft Recently Rebuilt Paul Grant For Sale - Parts 0 December 11th, 2008 09:16 PM
Greasing bushings ronward Defender Technical Discussions 1 July 25th, 2004 10:30 PM
