Power to illumination terminal for Carling switch - Defender Source
Old June 5th, 2016, 06:03 PM
KualaLumpurExpress
Michael Gutch
1983/110
Looking for a little help on what is giving me some trouble:
I just installed 2 aux. Hella lights and two USB chargers into my 83 110 ROW 2.5 diesel. To run the lights I put in 3 Carling on-off illuminated switches; one for the lights and 2 for future goodies. I took power straight from the battery, through a fuse box mounted in the battery box, to the switch and back through a relay. For the USB's I also took power straight from the battery through the fuse box. Everything works great - thanks for all the posts which helped make this a success.
To illuminate the switches (when off) I was seeking a source of power that was switched; as I didn't think a constant source of power (from the battery) would be appropriate. I've been looking at the wiring diagrams but can't seem to find a easy post-switch power source to tap into for the illumination. Or is it ok to use constant power for these 3 switch LED's.
Thanks in advance for advice!
Old June 5th, 2016, 11:18 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Switch illumination generally comes from the side light or dash instrument back light cct., look for red wires with a white trace.
Old June 11th, 2016, 12:22 PM
KualaLumpurExpress
Michael Gutch
1983/110
Thanks Andy for the reply - I actually tapped into a white wire coming from the ignition switch as I didn't have a RW wire. The old wiring diagrams indicated a W wire powered the warning lights. It was the one - and the switches are now illuminated with the ignition on only. Thanks again for the steer!
switch
Battery terminal option Jymmiejamz Defender Technical Discussions 28 June 3rd, 2016 08:11 PM
LR3 battery terminal clamps Grover Misc. Chit-Chat 7 January 22nd, 2014 07:07 AM
Help! Accidentally touched two wires while installing carling hazard switch, car died bradfordish Defender Technical Discussions 3 August 11th, 2013 08:28 PM
MUD Pod w/ 6 gang Carling switch mount jefhuf For Sale - Parts 8 August 23rd, 2012 12:02 PM
Optima Battery Aux terminal Screws sflash868 Defender Technical Discussions 1 June 5th, 2009 01:33 PM
