Post 2002 Door - Defender Source
Go Back   Defender Source > Build-up's, Projects & Registry Profiles > Smaller Projects
Old August 16th, 2012, 06:28 PM
trumphair
Martin
97-D90
Post 2002 Door
My old door was cracked and beaten on my '97 NAS so I pieced together a post-2002 style door. Bought a new bare door from the UK. It ended up not being too bad and I reused a decent amount of hardware from the old door. This link helped a ton with a few random part numbers that I needed. I was definitely surprised at how fast the shipping was on a lot of stuff from the UK. Faster than what I have experienced from the major parts sources here in the states.
http://www.landroverexpedition.com/t...td5-rear-door/
ID:	55891   Click image for larger version
Old August 16th, 2012, 06:40 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Looks good! I've got one sitting in my garage I have been trying to motivate myself to go get painted Thanks for that link.
Are you using a Discovery 2 tire mount?
Old August 16th, 2012, 07:52 PM
leastonce's Avatar
leastonce
Jason England
D-90 White 95 SW #65
despite what most people on here seem to think the UK is not a 3rd world country ... just because the ignore emails ... and taking off the VAT prices are much better!
Soapy water / KY jelly, etc. is is basically a must. Yes, good idea to remove trim panels - only takes 5 more minutes to do so.
Car Camping Collective founding member and Chief Executive Officer
Cat Camping Collective founding member and Chief Executive Officer
Old August 17th, 2012, 08:26 AM
trumphair
Martin
97-D90
I had a Mantec carrier on before the swap so I decided to keep it since it was already drilled into the body. All I needed was a new backing plate that fit the different mounting holes on the new style door but other than that every fit perfectly.
With that being said, if I hadn't already had the mantec I would have just went with the Disco mount. Solid and simple!
Old August 17th, 2012, 01:42 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
Where did you get the bare door and parts from in the UK?
ATW!
- Jon
Old August 17th, 2012, 02:37 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Yeah, what he said.
Old August 18th, 2012, 12:34 PM
trumphair
Martin
97-D90
Bought the bare door and a few bits from Paddock. Whatever i didn't get there I got from John Craddock.
http://www.paddockspares.com/bic7102...-2a622423.html
Old September 5th, 2012, 08:41 PM
Talleyrand's Avatar
Talleyrand
John
1998 Defender 110 CSW 300Tdi
Cool, I also have a 2002+ rear door awaiting bandwidth to go on. I also have a Mantec carrier. Where did you get the new backing plate, from Mantec?
Cheers,
John
Old September 10th, 2012, 05:39 PM
trumphair
Martin
97-D90
Got the matching Mantec backing plate from Keith Gott.
http://www.keithgott.co.uk/
door
2002 Cannondale Gemini Dfndr90 For Sale - Parts 13 January 10th, 2005 06:27 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Door hinge pin mspell Defender Technical Discussions 1 September 8th, 2004 04:14 PM
Need rear SW door Chris Cox Wanted 0 August 21st, 2004 04:11 PM
entire post not displayed artm Support & Suggestions 7 October 28th, 2003 09:14 AM
