Plastic window repair - Defender Source
Old January 15th, 2015, 09:39 AM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
My rear soft top plastic window was folded a couple times and with the cold it cracked bad and needs replaced.
Anyone ever have the window replaced?
Mud Ruts Off-Road Rover Repair shop 614.301.1574
Old January 15th, 2015, 09:44 AM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Same thing happened to me a couple seasons back. Had Chris from Rovertek (amazing guy) take it to a marine repair guy. Easy fix, couple hundred and it looks great.
Look for a marine/boat repair shop as they work with the exact type of windows that our soft tops have.
Old January 15th, 2015, 10:04 AM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
Originally Posted by jruti View Post
Same thing happened to me a couple seasons back. Had Chris from Rovertek (amazing guy) take it to a marine repair guy. Easy fix, couple hundred and it looks great. Look for a marine/boat repair shop as they work with the exact type of windows that our soft tops have.
Good to know.
I'll give it a shot.
Old January 15th, 2015, 10:56 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
I did the same thing last winter, cost was $100 and they also stitched in middle straps to keep the rolled up sides from sagging. Winter is a good time for this, the boat shops aren't busy and are happy to have the business.
Is there good metal or plastic fan replacement for the plastic D90 radiator? Neil McCauley Defender Technical Discussions 8 December 12th, 2011 08:30 PM
plastic/vinyl window slit repair GaryBaxter Defender Technical Discussions 3 April 5th, 2011 10:40 AM
plastic window stud sleeves jstrong98 Wanted 4 October 22nd, 2004 10:24 PM
Plastic Window Sleeves Glenn_Guinto Defender Technical Discussions 12 June 2nd, 2004 01:46 PM
