Oil Cooler Lines tread size? - Defender Source
Old March 31st, 2008, 08:04 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Smile Oil Cooler Lines tread size?
Hello,
Does anyone know what sizes are the actual " tread size" going into the radiator & filter plate on a 94 D90?
The I guess there is always one more way to beat this topic even more..
Old April 2nd, 2008, 08:44 AM
Grover's Avatar
Grover
Radiator-I can't remember, I know it's a pipe thread
Filler Plate- I am assuming you are refering to the oil filter sandwich plate. There are two different sizes: 18mmx1.5 and 20mmx1.5
Check out ECR's website:http://eastcoastrover.com/110oillines.html
This board has lot's of info on this topic...
Cheeers...
Old April 2nd, 2008, 10:48 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Thank you for info, this is my next project.
All the best.
Old April 2nd, 2008, 12:00 PM
Grover's Avatar
Grover
...it is very important to upgrade the oil lines...I can't believe that some people put if off...
Old April 8th, 2008, 04:21 PM
madcowdungbeetle
Carter
Stock Oil Filter Spacer thing is 18 x 1.5mm, Radiator is 3/8" NPT if I recall correctly. I just made up my own Aeroquip parts list usning -8 AN for my oil ines Monday.
Old April 15th, 2008, 12:51 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
This is what I'm trying to do, any chance you can forward this parts list?
Thanks in advance.
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil Cooler Adapter O-ring Size dnewman9 Defender Technical Discussions 0 September 5th, 2004 12:30 PM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
