Non-ABS RRC hubs? - Defender Source
Old November 6th, 2013, 09:56 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Non-ABS RRC hubs?
Someone here may know...
So I'm replacing the 3rds and axles in my non-ABS '91 Range Rover with the 3rds and axles from my ABS '91.
First time I've torn into the non-ABS truck.
First off, the drive flange bolts are smaller on the non-ABS truck so my question is...
Can I just run the ABS hubs on my non-ABS truck?
Rent my
Old November 6th, 2013, 10:05 AM
Yes, as long as the stubs are right for the hub bearing distance.
Old November 6th, 2013, 10:17 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
What is the hub bearing distance?
Worst case---I have to change the spindles as well?
Rent my
Old November 6th, 2013, 10:21 AM
Maybe just move the stubs over as well just to be on the safe side.
Old November 6th, 2013, 11:32 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
OK, thanks.
Now that I've got both off side-by-side, the inter bearing distance on the non-ABS hubs is bigger---requiring longer stub axles.
Looks like I'll just try and move the stub axles over too.
------ Follow up post added November 6th, 2013 11:34 AM ------
When you say non-ABS, it usually refers to the mushroom capped axles. Doesnt the 91'(hunter) use a broached drive flange like the ABS RRC, an later Disco/D-90?
-Jeff
Hunter has the mushroom axles.
Rent my
Old November 6th, 2013, 11:43 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Stub axles
ABS on left--non ABS on right
Rent my
Old November 6th, 2013, 11:55 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
BTW, one other little tidbit for anyone putting D90 3rds in a RRClassic....the axle housing requires longer studs.
You have to replace those short studs at the 2-4-8-10 o'clock position because the 90 3rd flange is thicker.
ID:	83658   Click image for larger version
Rent my
Old November 6th, 2013, 12:16 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Good to know.
So did you actually break and axle or CV, or are you just swapping to 24spline diffs?
-Jeff
Swapping in 24 spline ARBs w/ 4.11 gearing and some 9 year old GBR axles!
Rent my
Old November 6th, 2013, 01:23 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Also, I recommend changing to a magnet diff drain plug.
If you're changing 3rds or just draining the oil, put in a magnet plug.
ID:	83664   Click image for larger version
Rent my
Old November 6th, 2013, 07:19 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Have you considered a weld on pipe cap in place of the stock sheetmetal cover?
-Jeff
No, I'm not that kind of hardcore wheeler. I mostly webwheel and spin yarns around the campfire at eastcoast events. LOL
Now, on a serioooous note...the rear end is almost ready to put back together. The 3rd is in..(gud lawd that thing is heavy...)
I'll use the ABS stub axles + hubs to reassemble.
Anyone know about the front end??
Are non-ABS swivels/mushroom axles all different?
My question is...if I have to tear down the front axle to removing the swivels/3rd/axle/cvs.....it may actually be easier to just unbolt the entire housing and swap it over!!!
Rent my
Old November 6th, 2013, 07:42 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Oh I know they're different...I'm already running non-ABS 2522 Ashcroft cv's in the ABS swivels.
http://www.ashcroft-transmissions.co...od&productId=3
But can I pull the mushrooms/cvs + inners out and swap these in?
Using the matching stub axles and hubs of course...
Rent my
Old November 6th, 2013, 09:19 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
That's right...I forgot about those needle bearings!
I already put the bronze bushings in my front stub axles(on the ABS truck) about 9 years ago.
Guess I'll see how they look when I pull the front end apart tomorrow...
Rent my
Old November 7th, 2013, 07:29 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Got the rear end back together.
"Right Stuff" gasket maker.
Old Skool GBR axles back in...
Old drive flange bolts on the left---ABS bolts on right==bigger
ID:	83721   Click image for larger version
Rent my
Old November 7th, 2013, 07:40 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yes,'91 County was the donor.
Got the front end apart down to the stub axle....
I hate swivel grease!
It looks like the Hunter used ABS swivels with mushroom style axles.
Test fitting to follow...
Look at those clean swivel housings!
And Briggs, no needle bearings in the non-ABS Hunter!?!
And what is it with those Land Rover gaskets? They take 30 mins to scrape off.
It's like the worst wallpaper you ever had to remove.
ID:	83723   Click image for larger version
Rent my
Old November 7th, 2013, 07:58 PM
Angle grinder with a wire wheel will whip that old gasket off in about two minutes.
Old November 10th, 2013, 10:27 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
1.Mushroom axle and hub off;CV still in swivel.
2.CV gone; inner shaft and swivel covered in goopy one-shot grease.
3.Tearing down the donor truck was hard---its like saying goodbye forever.
Also found out I was missing a brake caliper bolt...
4.With the drive flange cap removed you can see how these axles(AEU2522) stick out further.
5.Ashcroft CV ready to come out of donor.
6.Both axles/cvs out of donor truck. Both had rust spots on the middle of the axle. They got grease on the entire length for reassembly.
7. CVs looked good.
8. Splines looked good.
ID:	83931   Click image for larger version
ID:	83935   Click image for larger version
ID:	83937   Click image for larger version
ID:	83939   Click image for larger version
Rent my
Old November 10th, 2013, 10:40 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This was a 3 cigar weekend...
When you put D90 3rd members into a RR Classic you will have to replace 4 of the axle housing studs because the RR 3rd has a thinner flange.
Short studs next to longer studs.
Just put one of the nuts on and knock the studs out of the housing. Put your longer ones in and use a sleeve and nut and tighten the new longer studs into the housing.
Do this before wresting a heavy-ass 3rd into place with Right Stuff goop all over your hands and then finding out that 4 of your bolts are not long enough to put a nut on.
I found this out 10 years ago....
Short-Long studs ----- D90 3rd housing with thicker flange
Range Rover thin flange -------- Truck is waiting!
ID:	83943   Click image for larger version
ID:	83947   Click image for larger version
Rent my
Old November 10th, 2013, 10:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I originally bought Keith Kreutzer/Rovertracks axles back in 2003 and promptly broke 2 of them. They were the hefty 2522 cv size but There may have been some bad batches back then. He was good about it; Then I got the Ashcrofts and have been fine ever since.
1.ABS spindle/stub axle with bronze bushing I got from Keith 10 years ago-still good!
2.CV in, hub on and tight.
3.These are Maxi Drive flanges with Right Stuff sealer. That way if the bolts break, Right Stuff will still hold the flange to the hub and provide drive.
4.Shims and C-clip
5.Installed.
6.Wheel replaced.
ID:	83950   Click image for larger version
ID:	83952   Click image for larger version
ID:	83954   Click image for larger version
Rent my
Old November 14th, 2013, 10:52 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Does anyone know where I can source a replacement brass compression fitting---the really small one--for the ARB air line where it fits in the diff housing??
What I mean is, if anyone has sourced one of these at Lowes,Home Depot, Ace, etc...
I need it by tonight.
Rent my
Old November 14th, 2013, 11:13 AM
87 D110 (Ruby)
get it done!!!! See ya tomorrow Jeff
WTB pressure switch sensor for RRC ABS Baja 90 Wanted 2 April 17th, 2013 01:26 AM
FS: Brand New Wabco ABS Accumulator - RRC ajh For Sale - Parts 2 April 3rd, 2011 11:01 AM
Non-ABS hubs from RRC Gore Ranger For Sale - Parts 0 February 21st, 2009 10:58 AM
RRC ABS pump TanDisco1 Wanted 7 November 17th, 2008 01:59 PM
1991 RRC FS. Lots of New Parts. Mike M For Sale - Vehicles 4 February 14th, 2005 08:16 PM
