Ninety Slider Fab & Install - Defender Source
Old September 1st, 2013, 10:17 PM
d110pickup
Mike Pado
'97 D90 ST #1153
I typically read a lot more than I post but I thought I'd try to contribute for a change.
I bought a beautiful 97 D90 last year and I finally decided the crappy steps had to go. These things flexed way too much and offered little protection. Plus some idiot did a nasty job of welding them to the frame.
I'll document the build and y'all can make fun.
Here's a few before photos.
ID:	78794   Click image for larger version
Mike Pado
I'm not saying that stupid people should die . . . but maybe we could remove the warning labels & let nature take it's course.
Old September 1st, 2013, 10:23 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Here's a few more of the weld job & the frame rail behind the mounting plate. This was surface rust only. I wire brushed and sanded the rust and used a conversion coating before prime & paint.
Thanks for reading,
ID:	78798   Click image for larger version
ID:	78800   Click image for larger version
Mike Pado
Old September 1st, 2013, 10:33 PM
d110pickup
Mike Pado
'97 D90 ST #1153
I used 2x3, 3/16 wall steel tube for the slider and the round tube is 1 1/2, 1/8 wall. I decided to try something a bit different and cut each end with a compound angle, I wanted it to be the same angle as the fender lip. So that's a 45 one way and 10 the other.
Unfortunately this required a rather complicated sent up on the saw.
ID:	78803   Click image for larger version
Mike Pado
Old September 1st, 2013, 10:35 PM
Subscribed keep going!
Old September 1st, 2013, 10:41 PM
d110pickup
Mike Pado
'97 D90 ST #1153
The existing steps did have one redeeming feature, I was able to use them to block & clamp the new steel in place. Here are a couple of photos of some other components. The round tube fit perfectly and extends to the inside of the frame rails. The square tube will be cut into two parts and ties into the bulkhead bolt.
ID:	78806   Click image for larger version
ID:	78808   Click image for larger version
Mike Pado
Old September 1st, 2013, 10:54 PM
d110pickup
Mike Pado
'97 D90 ST #1153
I used a 3/16 strap as a spacer between the slider & the bulkhead, I welded it in later. I didn't like the idea of drilling a hole through the round frame tube and the new tube to hold the slider in place so I added a collar the the tube to prevent it from sliding further in and then added a 1/4 strap to tie into existing brackets on the frame tube. Yeah, I favor overkill sometimes. I think the photos will help this make sense.
Also here's a photo of the compound angle cut after I capped it.
ID:	78810   Click image for larger version
ID:	78812   Click image for larger version
ID:	78814   Click image for larger version
Mike Pado
Old September 2nd, 2013, 01:55 AM
Looks great. I would slather the tube that goes into the frame with grease or antiseize or the two tubes will rust themselves together. Also, if the bulkhead bolt (the big one) turns, now is the time to remove it and replace it with antiseize all over the shaft.
Old September 2nd, 2013, 06:24 AM
Once mine get made up I'm pretty confident that they'll get galvanized. That said I love the idea of grease before installing.
Old September 2nd, 2013, 09:58 AM
d110pickup
Mike Pado
'97 D90 ST #1153
Remember, I live in Georgia and the truck is always garaged. We don't have a rust problem here. That said the tube does have a good paint job.
More to come on the build.
Mike Pado
Old September 2nd, 2013, 10:12 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
It was a suggestion to prevent a known issue with those sliders. I always find it funny when ppl totally disregard good suggestions, what do you think is going to happen when you slide that nice paint job into that frame mount? Anyway good looking sliders! Not trying to be a dick, just saying! I have had to cut many of those slider style mounts off because they have rusted together! Good luck on your build
Old September 2nd, 2013, 10:21 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Nice slider build!
Old September 2nd, 2013, 10:28 AM
Pado, just put the grease &/or anti-seize in... It only take a minute... :-)
Old September 2nd, 2013, 11:25 AM
d110pickup
Mike Pado
'97 D90 ST #1153
Damn, if it makes y'all feel better I put anti-seize on the bulkhead bolts while they were out (one at a time) and this isn't my first rodeo with Rovers.
I don't post much but I've been fabing and working on these trucks over 20 years. I had series trucks before the Defenders.
I'll post the remainder of the photos & write-up later.
Mike Pado
Old September 2nd, 2013, 11:27 AM
Looking good. One suggestion I have is to change the mount in the front to not allow it to pivot. If you put that to any real work it will pivot up and hit the body. You should be able to search here for Bill Burke Sliders and see how his mount, or I could sent you pictures. If these are cosmetic then what you have is fine.
I love all your toys too!
charles
Originally Posted by pendy
I'm here for the D's
Old September 2nd, 2013, 11:38 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
x3 on lathering the hell out of it with anti-seize. I had to redo the sliders on my white 90 before I sold it. It took me a LONG time and a lot of sweet and cutting to get the old ones out. If it's a slider and is going to be used, there will be a lot of water and stress on it that will cause the paint to flake and things to want to fuse together.
Love the fabrication work. I am going to build my own sliders for the 110 and will check out what you did with these once I start to build them.
Old September 2nd, 2013, 11:40 AM
d110pickup
Mike Pado
'97 D90 ST #1153
charles
Thanks Charles, but I disagree on this one. The aft tube is 3/16 wall and runs through the frame rail. I've built them this way before & the owner beat the crap out of them but they didn't rotate.
These aren't for looks but I won't abuse this truck like past ones.
Mike Pado
Old September 2nd, 2013, 11:44 AM
We'll have to agree to disagree on that one
Old September 2nd, 2013, 11:55 AM
d110pickup
Mike Pado
'97 D90 ST #1153
Works for me. As I said, this is not a truck that is going on extreme trails, I've gotten that out of my system and it's too nice.
Mike Pado
Old September 2nd, 2013, 02:33 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
That is a beautiful truck. I think I drooled on it a little. Sorry.
Those sliders look nice as does all your other previous work I've seen. Will you be driving that to TN in a couple weeks?
Old September 2nd, 2013, 03:43 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Hey Jeff,
I don't know which truck I'm driving up, it depends on how much stuff I have to haul for the auction & raffle. This is the white 90 you saw last year at SAE.
See ya,
Mike Pado
slide
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Bench seat install in '97 hartop timcd90 Defender Technical Discussions 1 February 15th, 2005 01:57 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
