Ninety Slider Fab & Install - Page 2 - Defender Source
Old September 2nd, 2013, 04:34 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Looks good. To clarify the stock side steps are just there as a fabrication tool and aren't going back on?
-Jeff
They are scrap metal. But they did make it convenient to mock up the 2x3 stock.
Mike Pado
I'm not saying that stupid people should die . . . but maybe we could remove the warning labels & let nature take it's course.
Old September 2nd, 2013, 07:20 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Here's a few more project photos. No shots of bending the tube, it was done with a JD Squared Model 3 bender using a 4.5" radius die.
Cutting the round tube required a simple setup on the saw, except using it in the vertical position now. I've found this to be a foolproof (hey, it works for me) method of making the cut exactly parallel to the outside of the tube.
Thanks for looking,
ID:	78882   Click image for larger version
ID:	78884   Click image for larger version
Mike Pado
Old September 2nd, 2013, 07:29 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Next up is cutting the tube spacers & notching them to fit the 1 1/2 tube. I keep all up my short pieces for this purpose. They were notched using a notcher I got from the inventor, a guy named George Barnes about 25 years ago. Shortly after they came out they were copied.
ID:	78887   Click image for larger version
Mike Pado
Old September 2nd, 2013, 07:41 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Painted & installed in this set.
ID:	78890   Click image for larger version
ID:	78892   Click image for larger version
ID:	78894   Click image for larger version
Mike Pado
Old September 2nd, 2013, 07:50 PM
d110pickup
Mike Pado
'97 D90 ST #1153
The last set. I used coarse anti slip tape made by Wooster, got the 1" wide by 60" long roll.
This tape is polyurethane backed instead of paper and I believe it will be more durable. I used a hard rubber roller made for laminate application to apply it. I don't think there's another way apply enough pressure to this stuff. Also never leave a square corner on a tape like this, it'll be the first spot where it comes loose.
Thanks for looking,
ID:	78896   Click image for larger version
Mike Pado
Old September 2nd, 2013, 08:20 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
those look awesome. Good work man!!!
~Steve
Old September 2nd, 2013, 09:19 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Very nice .... Jealous of your shop, tools, welding and fab skills .... And you sliders. Well done.
Firemanshort
1980 Stage One 109
Sterling, VA
slide
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Bench seat install in '97 hartop timcd90 Defender Technical Discussions 1 February 15th, 2005 01:57 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
