Next projects starting... - Defender Source
Old December 3rd, 2010, 06:27 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
So excited for new tub cappings. Didn't get any feedback from the Technical Discussions, so I'm going to touch up the primer and get these painted before installing (rather than galvanizing).
Also have a reason to learn TIG now My new (to me) door needs a little love before paint.
ID:	33712   Click image for larger version
Old December 3rd, 2010, 06:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
make sure the holes line up before you put the new capping on. A lot of times they don't. Also if you don't galv make sure you prime well and prime the body too if there wasn't any paint under your old ones.
Old December 3rd, 2010, 07:10 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
hole alignment
Thanks Barry. Assume you mean the rivet holes? Was planning on checking those tonight and all others once I pull the top off. Hadn't thought about checking primer on the body, so thanks for the tip.
start, starting
Starting problem (occassionally) kolvedic Defender Technical Discussions 21 January 21st, 2012 11:12 AM
So what's on the list of projects for this year? Hans Misc. Chit-Chat 15 March 13th, 2006 05:52 PM
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
Help With Starting My D90! Davis Defender Technical Discussions 0 September 7th, 2004 05:13 PM
