New Zealand 1987 110 V8 - Defender Source
Old September 25th, 2014, 02:58 AM
Grumbly
T
1987 County 110 V8
Hello ladies and gentlemen, I've recently picked up my very first Landy and i'm after some advice.
It's a 1987 V8 110 County with 320,000kms on the clock. Runs very well, doesn't blow any smoke, drivetrain feels good and strong. Gearbox is noisy (bearings?). It leaks oil from just about everywhere but I was told this is quite normal and not to worry about it? I'd like to fix the leaks all together - am I dreaming?
I have replaced the clutch master cylinder last week as that started leaking all over the pedal.
I've re carpeted it and put a nice stereo in.
The bottoms of the doors are rusty so they will be done. No chassis rust so seems to be a very solid truck.
Now I'd like to put some money into it making it a reliable adventure beast. It's never going to be a tough truck and I don't want to drive through rivers up to the windows, but I will be doing some 'light' off-roading and this is where i'd like it to be reliable.
I'll be using it a lot over the coming summer here in New Zealand with my roof tent and doing a fair bit of fishing/hunting/camping/ski trips.
What upgrades should I be doing to ensure it's reliable off-road and what tips can you give me?
I was told something about raising the diff breathers - I see the wee tubes coming out of the diff, to I just replace them with longer ones and route them up to the engine bay? Is this all required to increase the potential wading depth of the truck?
I've bought a 15,000kg snatch strap. I'll get a shovel and an axe. Where are the best recovery points on these things? Seems to have two front and two rear - is this correct?
This is my first 4x4 so i'm new to it all and any advice is appreciated!
Old September 25th, 2014, 07:28 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Nice truck! More pics!
Not sure how the breather tubes on a ROW truck differ from a NAS spec, but on my '95 D90 the diff breather tubes extended to the engine bay. The fuel breather did not however so I extended that to the engine bay and used a Landy Lubber manifold wading kit to tie them all together and then ran a single tube to the roof line. If you're just doing light wheeling, I would at least ensure that they are all run to the engine bay just to be safe. I bought extra tubing and a Y tube-to-tube connector from McMaster Carr.
http://www.mcmaster.com/#push-to-con...e-wyes/=tvilcl
Good luck!
Old September 25th, 2014, 09:06 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Can you post some more pictures of your rear door? It looks like somebody cut the original and made it into a clam shell. Looks nifty. If you replace it, I want it!
110, v8
New Zealand 110 Surf90 The Flea Market 14 September 2nd, 2012 01:02 AM
Am I nuts for considering this for my 3 months in New Zealand? Roving Beetle Misc. Chit-Chat 9 November 14th, 2010 06:20 PM
Not the normal shipping question: New Zealand to USA? Roving Beetle Misc. Chit-Chat 13 November 10th, 2010 10:39 PM
Welp - Just booked my one way ticket to New Zealand for Dec! Roving Beetle Misc. Chit-Chat 18 November 1st, 2010 08:13 AM
Headed to New Zealand for a while this winter: Rover to buy? Roving Beetle Misc. Chit-Chat 1 October 26th, 2010 09:59 AM
