New TD5 hinges? - Defender Source
Old March 15th, 2009, 07:56 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
New TD5 hinges?
I would like to put some new hinges on my 90 - the old ones are worn and sag...
I have heard that the newer TD5 hinges are more robust and have a washer or other some such buffer to prevent metal-on-metal grinding...
Does anyone have any expereince with these newer hinges and if they can be fitted easily to a 94 NAS D90? (ie. are they different from an original hinge?)
Thanks!
Don
Old March 15th, 2009, 10:57 PM
bjf's Avatar
bjf
barry f
94 ST #395
Should work fine. Better design but uses the same mounting points
Old March 16th, 2009, 06:23 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I replaced mine with the new TD5 hinges on my 94 and no problems at all, the hinges do come a bit rough and need primer & paint. You will need a self etching primer to apply several coats and sand in between the coats...then the paint afterwards...all new stainless hardware should make it last for many years to come.
Old March 16th, 2009, 09:56 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Make sure you get the new style plastic pieces too as the footprint of the new style hinge is slightly different.
Old March 16th, 2009, 10:25 AM
DonFromWhitby
Don Andrews
Does anyone have a good source for these, and what exactly I should be looking for? Are they just "TD5 Hinges" or do I look for a particular year like "2002 onwards" or something like that?
Old March 16th, 2009, 11:00 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm not sure about pricing, especially since you are in Canada, but both George at Rover's Down South and Stephen at Safari Rover carry them and will have the plastic pieces I was talking about as well.
Old March 16th, 2009, 11:45 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I can get you the part# when I get home tonight and post....I did order mine and other parts from:
http://www.paddockspares.com/
Old March 16th, 2009, 07:04 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Here is the part#'s for the TD5 shims (gasket), you will need (2) per hinge
BOC 710040
Regards
Tom
Old March 16th, 2009, 08:36 PM
DonFromWhitby
Don Andrews
Thanks a bunch!
I've dealt with Paddock before - good guys - lots of strange parts - I picked up some spare drive shafts for my Series 3 LWB from them last year..
Would really appreciate the partno for the hinges themselves..
Cheers!
Don
Old March 17th, 2009, 06:26 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Here is the list of Part# as I purchased :
BDB710160 HINGE TOP RH FRONT DOOR
BDB710170 HINGE TOP LH FRONT DOOR
BDB710180 DOOR HINGE RH LOWER 2001 ONWA
BDB710190 HINGE DOOR LEFT HAND LOWER
BYG100140L BOLT FLANGED
BYG100150L TORX BOLT M8 x 55mm DOOR HING
ASR1459 NUT HINGE TO BULKHEAD FROM WA
NY108041L NYLOC NUT M8.
Regards
Tom
Old March 17th, 2009, 08:00 AM
DonFromWhitby
Don Andrews
Regards
Tom
So for quantities...?
1X BDB710160 HINGE TOP RH FRONT DOOR
1X BDB710170 HINGE TOP LH FRONT DOOR
1X BDB710180 DOOR HINGE RH LOWER 2001 ONWA
1X BDB710190 HINGE DOOR LEFT HAND LOWER
8X BYG100140L BOLT FLANGED
8X BYG100150L TORX BOLT M8 x 55mm DOOR HING
8X ASR1459 NUT HINGE TO BULKHEAD FROM WA
16X NY108041L NYLOC NUT M8.
plus the shims:
8X BOC 710040
Does that look about right?
Old March 17th, 2009, 08:25 AM
You also have to trim the door cappings slightly.
Name:	2006_08270115 - resized.jpg
ID:	18319   Click image for larger version
Name:	2007_02160020 - Resized.jpg
Old March 17th, 2009, 10:49 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I don't have all the part numbers handy to check, but I would get stainless hardware to replace the original. Stig's has a pretty good selection of stainless hardware for a fair price with the exchange rate as it is.
http://a2stainless.co.uk/Defender_B22EP.aspx
Old March 17th, 2009, 11:17 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
The quantities look correct Don...
JimC's point about the trimming is correct, I used a small air powered trimmer....gently, very gently and it comes out perfect...to level the door I used some wooden shims and taped the door shut once I had it in place.
Old March 17th, 2009, 11:38 AM
My cappings needed to be repainted anyway, so I took a dremel tool and carefully sliced off the part that was in the way. They were of course off the door at the time.
Old March 20th, 2009, 07:33 PM
DonFromWhitby
Don Andrews
How did you repaint them? I'm only used to painting large sections of trucks with my hvlp..
Also, Paddocks hasn't returned my emails as yet for those parts - it may be time to make a phone call...
That looks like a great job..
Is there any trick to getting the retaining nuts to line up? I haven't done S3/Defender hinges before so I'm a bit ignorant of what's require to fit new ones... do the old nuts just drop inside the channel when you remove the hinges?
Old March 20th, 2009, 08:46 PM
The nuts on the bulkhead side are captive nuts in a "J" shaped clip, so they just stay put. LenB repainted my cappings for me when I lived in CA - he's pretty talented that way. Nothing much to it. I did do a lot of sanding and prep though.
td5
Painting Td5 Hinges Black tebby Defender Technical Discussions 6 December 14th, 2009 05:03 PM
TD5 Hinges (painted British Racing Green) SafariHP The Vendors Loft 0 June 25th, 2009 12:59 PM
New Genuine TD5 hinges and hardware FS SafariHP The Vendors Loft 1 May 5th, 2008 09:38 PM
New TD5 Style Door Hinges FS SafariHP For Sale - Parts 25 March 25th, 2008 12:21 PM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
