New project, window upper new posts - Defender Source
Old November 7th, 2012, 09:26 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Ok, so I have been looking to replace my upper windows for a while now and I don't have an extra testicle to spare. So I jumped into this yesterday, one side the posts were completely rusted through and the other side I had to cut off bc they were seized up. So costs where $4.75 for four six inch grade eight bolts an $10 for a pc of 1x3. I cut the 1x3 on two opposite corners and split the bottom frame. I bent up the frame to see where the spot welds were and marked and drilled them out. I cleaned all the excess rust laid down rust converter to help for the future. I put the bolts in the hole held up the frame and tacked the bolts in place. After marking the 1x3 I drilled the holes. I finished welding the bolts to the frame, placed the 1x3 in place and tacked that in place. I checked the posts again to make sure that they didn't move before welding up. Welded er all up an slid it back into place. I also took a pc of 1" aluminum to cap the bottom, installed that with pop rivets. The one went in easy the other I had to bend the posts a little to coax it into place. I still need to sand prime and paint, but at least I can keep my testicles an keep them warm all at the same time. Total time about five hours and total cost less than $15.
ID:	60488   Click image for larger version
ID:	60491   Click image for larger version
ID:	60493   Click image for larger version
ID:	60495   Click image for larger version
ID:	60500   Click image for larger version
Old November 8th, 2012, 12:05 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Good job! I luckily had a fairly easy time getting the bolts out of my door tops. What are you going to do about the window lock?
MUDSUX
Old November 8th, 2012, 09:39 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I pulled them out and just need to measure, cut and pop in place. Main goal was to get windows in so I can drive it. Ppl look at you funny in a parka when it's 45 degrees out!
window
94 Yellow ST Project $12k/offer Colorado dnewman9 For Sale - Vehicles 9 January 20th, 2006 08:34 PM
Disco/Defender Hybrid Project RedRhinoProducts For Sale - Vehicles 3 December 11th, 2005 09:14 PM
Window removal 1/2 way there Help!! paulb Defender Technical Discussions 2 May 11th, 2005 04:13 PM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
'97 SW window handle crank J4hand Defender Technical Discussions 2 August 8th, 2004 08:51 PM
