New mods to the 1994 NAS Defender 90 - Defender Source
Old September 13th, 2014, 09:57 PM
wmatos1001's Avatar
wmatos1001
William
Added a new Snorkel kit and 1994 correct amber front driving lights (previous were clear). Also completely replaced all old and rusted hinges and bolts with factory OEM hinges and stainless bolts. What do you think? Next is stainless factory styled exhaust and OEM shocks and springs.
CORRECTED SNORKEL! Thanks everyone
ID:	102839   Click image for larger version
ID:	102841   Click image for larger version
ID:	102843   Click image for larger version
ID:	102845   Click image for larger version
Old September 13th, 2014, 10:17 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Looks great. Isn't your snorkel main pipe upside down though?
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Looks very nice! Tasteful mods, love it. I have the new hinges as well sitting in my garage all painted and ready to go, just haven't found the time to get them on. Let me know if you ran into any issues during the hinge install or if you have any tips on installing them. About how long did it take for the hinge install? Thanks, truck looks awesome.
Old September 13th, 2014, 10:20 PM
wmatos1001's Avatar
wmatos1001
William
I hope not? I don't think so. Didn't come with any directions but it did match the photos that were on the site I purchased the kit from.
Old September 13th, 2014, 10:27 PM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Believe Rankar is correct. The bend in the tube allows the breather to sit more parallel to the ground. This will also take a little of the slack out of the flexible tubing that is bunching up a tad. Here's a pic for reference...
Old September 13th, 2014, 10:28 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
It is upside down.
The snorkel top should be straight up, not tilted back.
Rent my
Old September 13th, 2014, 10:30 PM
wmatos1001's Avatar
wmatos1001
William
Took about 4 hours total. Maybe a bit more. Tips on the hinges. Hit them with some rust remover repeatedly before you start to work them off. Also obviously take out door card inserts to get at back of the bolds that mount to the doors. Also I used an impact driver (kind you hit with a hammer) to get the screws started. But be very careful to not hit too hard with the impact driver/hammer to dent the doors.
I was able to get all bolts and hinges off for the doors successfully without any issues. Also when installing the new ones be sure to take one old one off and put a new one back on. Do not take both off so the door has no hinges at all. Also, when putting one hinge on at a time make sure the door is closed and locked tight. That way the door will align perfectly when you are done with the door hinge install. Mine aligned perfectly, the doors shut way tighter than before. For the door hinges and rear hinges best to have two people. This is not really a one man job.
For the rear two hinges I ran into two bolts I could not get off at all. Had to drill them out. That took about an hour more. If you are doing the rear hatch be sure to get access to the rear of all the bolts from the interior. But there is one set that bolts to the car you can only access from behind the rear bumper underneath. Best to have an open wrench (not a socket) to secure the bolts as there isn't much room back there.
Good luck and it is well worth the work. I can't believe how great they look and doors slam shut like a vault now. Also no more wind noise around the door frame since they sit tighter now.
Old September 13th, 2014, 10:33 PM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Awesome! I'm even more excited to get them installed now that I hear your doors shut tighter than before.
Old September 13th, 2014, 10:34 PM
wmatos1001's Avatar
wmatos1001
William
It is upside down.
Thank you both. I do appreciate it. I will need to correct that although I can't lie I am dreading it a bit. Was not that easy to get it on!
Old September 13th, 2014, 11:43 PM
wmatos1001's Avatar
wmatos1001
William
Good luck!
mod, defender, defender 90, nas, 90, 1994
Beefeater - 1994 D90 NAS :: 1994 Land Rover Defender 90 Raz Defender & Series Truck Registry 2 August 6th, 2015 12:22 PM
1997 NAS Defender 90 Wagon - lots of mods shredia For Sale - Vehicles 6 September 18th, 2007 08:42 AM
Help me test out my new mods.. (NY) sflash868 Trips, Trails and Events 1 June 13th, 2007 12:19 PM
