Need some advice on cappings - Defender Source
Old April 25th, 2014, 10:19 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
guys, I'm prepping the SW 90 for some paint and I'm dreading changing the cappings on the tub.
the rn boys said that the nas cappings have been on backorder since december and run $600 total ($300 a piece for the left and right side). they've suggested fabricating it and i'm down with that, but it most likely won't have that bevel in the capping. don't get me wrong, i'm not trying to do a show car here, but a piece like that would be nicer if original looking.
any ideas on where i should look for cappings?
Old April 25th, 2014, 10:23 AM
Are yours completely dead? I would imagine that you could salvage existing ones with sections from secondhand ones. The NAS specific section is only the front around the seatbelt / bulkhead as data I know.
Old April 25th, 2014, 10:31 AM
rankar's Avatar
rankar
The right side (pictured) is the worst side. There's only rust stains on the left. KClick image for larger version
Old April 25th, 2014, 10:44 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
pull them blast them and repair them they do not look that bad. I am sure someone on here would have a scrap set that they could cut a section out to weld in if necessary but I am guessing that you can just us some standard flat stock.
You could always galvanize them as well
Old April 25th, 2014, 11:20 AM
X2 and galvanize them rather than paint them.
Old April 26th, 2014, 07:33 AM
rankar's Avatar
rankar
Wouldn't that be odd to have the cappings left galvanized? I've seen this done on series but a 90?
Old April 26th, 2014, 08:24 AM
Galvanize then paint them if you don't like the look.
Old April 26th, 2014, 08:54 AM
rankar's Avatar
rankar
Yup, word.
Old April 26th, 2014, 01:00 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I think the ST door capping will help with the splice and they are available new and used
good luck with your search
Old April 26th, 2014, 05:36 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
If you have them off I highly recommend galvanizing them. Mine looked about that bad. Media blast them, make the repairs, galvanize and paint and never worry again. The quality level of a new set still suck.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old April 28th, 2014, 06:26 AM
rankar's Avatar
rankar
Thanks, I'll look at an ST and will definitely do the galvanize and paint thing. Sucks about the quality of a new one.
advice
Need some tire advice mightymo Misc. Chit-Chat 13 April 19th, 2011 06:37 AM
Need some advice on Nato rims ddrotts Defender Technical Discussions 12 August 12th, 2010 04:53 PM
Need some help/advice with rear seat installation Paul Davis Defender Technical Discussions 4 July 20th, 2006 10:01 AM
I need some advice- RR LWB surfd90 Defender Technical Discussions 3 February 23rd, 2005 02:11 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
