Need help NAS 90 A/C won't cool - Defender Source
Old June 25th, 2015, 01:22 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
The compressor turns on, and is charged. The fan works only blowing hot air. Where should I start?
Old June 25th, 2015, 01:24 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Does the clutch engage on your compressor and is the high pressure line hot (the thinner tubing one) at the compressor?
Old June 25th, 2015, 01:26 PM
high side and low side pressures ? If the compressor clutch is engaging and the cooling fan up front is running and the inside fan is blowing, the pressures will tell if the expansion valve is stuck or not.
Old June 25th, 2015, 02:50 PM
Jbullis's Avatar
Jbullis
Jason Bullis
The high pressure lines does get hot...
Old June 25th, 2015, 10:29 PM
Jbullis's Avatar
Jbullis
Jason Bullis
low pressure= 41
hi pressure= 265
90, ac, nas
Need something from eBay UK, they won't ship JFD Misc. Chit-Chat 2 December 13th, 2011 10:22 AM
Now it won't start. Need some help please. RickM Defender Technical Discussions 20 December 10th, 2011 08:31 AM
Won't crank, Won't start. revor Misc. Chit-Chat 4 September 16th, 2010 09:48 PM
Surging AND now it won't start again... in dire need of help Coug D90 Defender Technical Discussions 0 June 24th, 2010 04:07 PM
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
» Defender Registry
The Cube II
Cube II
#304
TRS
Add your Defender
