NAS ST swing away tire carrier rebuild - Page 2 - Defender Source
Old June 5th, 2012, 11:37 AM
bjf's Avatar
bjf
barry f
94 ST #395
Reviving this thread. Quick question.
I see ECR recommends 6659k34 for the bushings but Charles said 6659k35. I see the 35 is a bit longer. My question is if you use the longer one I think it blocks the grease port. If the factory ones are longer than I will go that route. Just curious before I get some.
Old June 7th, 2012, 09:53 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Not sure, I purchased the ones that ECR posted about. Should have been a bunch of them in the package as well as the old ones.
Old June 7th, 2012, 11:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks will look through it all.
Old June 8th, 2012, 11:34 AM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Barry-
Let us know what you end up with and how it works out... I'm about to get my tire carrier refinished and will want to replace the bushings.
Jay
Old June 8th, 2012, 11:48 AM
bjf's Avatar
bjf
barry f
94 ST #395
I helped Mark from the board replace his and he used the ones ECR recommended. We used a long bolt with washers to press the bushings in. There was no issue. When I tried to do the same with mine, the bushings went in fine but I noticed that the bushings are deforming slightly when I do it making the bolt hard to get in.
I was going to try the longer bushings that Charles said he used but I feel those look incorrect because then the grease ports are completely blocked.
Old June 8th, 2012, 11:51 AM
You can just cut them down if you feel they are too long.
Originally Posted by pendy
I'm here for the D's
Old June 8th, 2012, 12:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
Hope you are joking. They sell 16mm (ecr) recommendation and 20mm (yours). Cutting seems a lot of trouble for a few mm.
Old June 8th, 2012, 12:15 PM
It sounded like you had them already. It's not that complicated - buy shorter ones if you think they are too long, or if you have them, just cut them down. I don't think you need some huge gap for the grease though. If you can pump grease in then it will work. I don't think you can go wrong with a bigger gap either though.
However, as with anything rover, if you have any doubt, please go with the ECR recommendation over mine
Old June 15th, 2012, 09:20 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I don't recall the brand - will have to ask my friend.
Did you ever find out what paint this is? I looked at my paint job on the sliders, front bumper and rear quarter protectors and that krylon spray paint (was that rustoleum?) is just not cutting it. I have chips at almost every corner. Feels like the paint is not grabbing on the primer very well... Front bumper was por-15 IIRC and since I did not go to bare metal, rust is coming through (or maybe that was not por-15? Can't remember anymore).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old April 16th, 2013, 09:25 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Hey Dave
I was just curious how this worked out once you put it back together? And what hardware did you guys use?
Old April 16th, 2013, 09:30 PM
I galvanized mine with the bushing still in it. Drilled and tapped everything (the big die for the main studs was expensive) and refitting original bolts with lots of anti sieze and grease. I got the new rubber bump stops through the dealer.
Old April 18th, 2013, 08:16 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Those bolts are crazy expensive!
Anyone modify the brackets and use regular old bolts?
Old April 18th, 2013, 08:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have a set of the replacement ones you can have. It's weird, the bolts fit in the bushings fine but when I pressed the bushings into the carrier the bolts wouldn't fit anymore. I tried a few times. Wasted a bunch of bushings.
Old April 18th, 2013, 08:31 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Sounds good, but I wonder if I'd have the same problem?
Did you get the original LR ones or the macmaster Carr ones?
Old April 18th, 2013, 08:33 PM
I reamed out the bushings with a drill after I galvanized the whole thing.
Old April 18th, 2013, 08:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
I ended up using genuine. The McMaster Carr ones I had an issue with.
Old May 7th, 2013, 03:09 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Any thoughts on using plastic bushings in place of the brass?
carrier, nas, rebuild, tire, tire carrier, wing
Free NAS 110 Tire carrier and custom bracket to mount mantec on ST bjf For Sale - Parts 16 August 10th, 2009 05:39 PM
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
swing away tire carrier d90/d110 rvrnut110 Wanted 0 November 12th, 2005 06:21 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Modify ST Tire carrier for SW use? dnewman9 Defender Technical Discussions 1 June 27th, 2004 06:06 PM
