NAS ST Cargo Mat Install (+ Question about rear speaker box fit) - Defender Source
Old April 4th, 2016, 03:34 PM
jperakis
James Perakis
94 ST
PO did a piss poor job of lining the rear of my truck.
It's rhino lined up to the cappings but he/she had zero prep work done and all the bolts and brackets were lined as well.
Spend a couple hours removing my rear seat and associated hardware, then did my best to clean the ridiculously faded lining.
Topped it off by installing a LR branded rear cargo mat.
I love the look of the mat. High quality thick rubber that should do a much better job of keeping my dog from sliding around in the back - and it acts as a solid sound dampener to boot.
The only issue I ran into was the installation of the rear speaker boxes.
Since there is now a ~1/8" thick mat the boxes don't fit flush.
Would love some tips to deal with that
ID:	146594   Click image for larger version
remember two things...
Old April 4th, 2016, 10:22 PM
as a tip pull up the rubber lining and fit them in then lay the mat over the speaker box lip.. (the mat is cut for this btw..)to hide the screw at least mine is ..
or trim the top of the speaker box plastic.. they are basically force fit with a screw to keep them in.. get them under the top lip and shove them in gently they should flex.. but remember they are old, cheap plastic, be easy with it..
also
otherwise your looking at a shorter aluminium one
(Edited to change the order of advice.. Force fit without trimming, pull the mat up then trim..)
95' D90 - daily driver..
Old April 5th, 2016, 12:49 AM
Another tip- pull the mat back out and use pond liner with contact adhesive to reinforce the places where the mat bends. Otherwise you run the risk of having split edges in the most annoying and inconvenient places.
nas
FS: D90 NAS Rear Cargo Mat JJ14 For Sale - Parts 1 June 7th, 2015 10:00 PM
Tuffy box removal/ Rear load mat install aosias Defender Technical Discussions 5 March 7th, 2008 06:16 AM
NAS 97 SW D-90 Cargo Mat Frankie Carbone Wanted 0 August 20th, 2007 02:01 PM
Atlantic British Rear Cargo Mat $200 HUMMER80401 For Sale - Parts 3 May 20th, 2006 11:48 AM
stock rear cargo mat jstrong98 For Sale - Parts 6 April 13th, 2004 09:17 PM
