More Heat! Yea! - Page 2 - Defender Source
Old February 27th, 2015, 09:47 PM
the rover shop
shayne young
Would be simple enough to run flexible ducting up under the floor and pipe it into the fresh air intake from say... Under your seat in the battery box for example.. Then it's just a matter of blocking off the fender intake and voila..one interior air recirculating system.., you could just partially open the fresh air Intake grate and then you get a small amount of fresh air with your recirculating air.. Easy enough to have it installed in winter and removed during non cold months..!!
And I have seen a modification which uses a larger fan and is supposed to provide a lot more air flow..it uses an a/c delco blower motor and cage from memory.. Common upgrade in England..
Old February 27th, 2015, 09:58 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
That sounds like it would work nicely...hell you could put in a Y pipe as it goes into the blower that has a damper in it so you can mix as much fresh / recirculated air as required..wow...spending way to much time with my HVAC contractor..
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 27th, 2015, 10:13 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Anyone try on of these?
http://www.allisport.com/product-cat...heater-matrix/
I mean hypothetically it would increase heat output
Old February 27th, 2015, 11:35 PM
Originally Posted by NPT90 View Post
Anyone try on of these? http://www.allisport.com/product-cat...heater-matrix/ I mean hypothetically it would increase heat output
I'm sure they are nice but a complete much larger replacement heater is substantially cheaper.
Old February 28th, 2015, 10:31 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
John, anything you would do differently the second time around? Im thinking I'm going to follow your lead on a heater......
Old March 2nd, 2015, 04:45 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
Originally Posted by Overlander View Post
How in God's name can such an esteemed member of this forum, purveyor of 6 figure Rovers and business partner with ECR not know about this?
Seriously, I know your joking...that was a good one.
sadly not a joke.
not business partners with them either. remember i am just a guy with fancy pants.
Old March 2nd, 2015, 05:45 PM
The one I used is a tight fit and puts out more heat than needed in the 90. The Summit Racing one would be a lot less work and be fine for a 90. For a 110, mine would be great, but I would suggest you need to do more ducting work to push some air into the back seats.
You would get a bit more out of mine with a larger bulkhead hole, I think, but I wanted to be able to put the stock heater back, if desired. I really need to measure the output of it now that I have the vents opened up and the intake on it. Maybe in a bit, once winter lets off. I'm guessing I'm up around 9 kW (31000 btu-h) as it sits.
Keep in mind, this is all for a LHD. A RHD provides a lot more restrictions in space for the heater and the bulkhead hole size.
Old March 2nd, 2015, 06:18 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Originally Posted by d90boy View Post
sadly not a joke.
Keith, have a full length drop curtain in that truck? World of difference. Did that years ago - Great purchase.
Disco Parts Truck.... oh yea. madcowdungbeetle For Sale - Vehicles 11 April 4th, 2010 02:46 PM
Yea or Nay? themaxx Misc. Chit-Chat 21 July 4th, 2008 01:29 AM
Rearward facing racing seat. Yea or Nay? Neil McCauley Misc. Chit-Chat 13 June 23rd, 2008 10:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
Need heat! howellm70 Defender Technical Discussions 1 January 21st, 2004 10:19 PM
