Maxtrax mounting plates for Front Runner rack - Defender Source
Old June 19th, 2015, 03:03 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
1995 NAS Defender 90
I designed a set of mounting brackets for the Maxtrax mounting pins to attach to so that they can be mounted along one of the cross bars on any Front Runner or Hannibal rack that has a slot in it. Here are some pictured of the first prototype.
ID:	123173   Click image for larger version
Tiktaalik™
Old June 19th, 2015, 05:59 PM
How are the Max Trax release? Wing nuts?
Old June 19th, 2015, 06:07 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Maxtrax uses a proprietary cam lock post...I would expect these brackets to accommodate that setup.
-Ash
Geared Restoration Co.
352-572-3236
Old June 19th, 2015, 07:57 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Here is one of the mounts with the Maxtrax pins shown from the top. The brackets will fit both the Maxtrax pins and any other bolt of the same diameter. This is just a prototype and I haven't mounted it up yet. Hoping to get it installed in time for the NW Overland Rally next week. So I can test them out properly. I'm not saying these will be for sale just yet. They'll eventually be hard anodized black. The bend is really just there to add stiffness and to prevent the flat part from vibrating when bouncing down dirt roads.
Tiktaalik™
ac, mount, rack
Front Runner Outfitters 110 Roof Rack COJ142 For Sale - Parts 33 August 6th, 2014 08:16 PM
Roll Cage Clamp for Front Runner Rack Manimal Smaller Projects 17 September 25th, 2013 12:57 PM
MAXTRAX -- is there a less expensive alternative? 30A Wanted 20 September 17th, 2013 09:49 AM
Mounting a Font Runner Roof Rack to a NAS Viton Defender Technical Discussions 2 February 17th, 2012 06:55 PM
Hannibal/Front Runner Rack + Pelican 1600 Case Mounting Options Manimal Series Technical Discussions 7 April 20th, 2011 08:48 PM
