M101CDN coming along - Defender Source
Old April 27th, 2014, 08:04 AM
ezzzzzzz
Mark Garrenton
I picked up this trailer to build my camping rig. It was disassembled, chopped up for the tail gate, longer A frame arms fabricated and extended tube out the back for a rack. The bed was reinforced with two extra cross members. All those parts were galvanized before etching primer, seam sealer and more etching primer and then some paint. The springs have been blasted, painted and reassembled using poly slider material and new hardware. I rifle drilled and relieved the spring/shackle bolts to provide for lubrication. Wiring is almost complete which will be LED and include backup lighting. It has received a SOA conversion on the custom axle I built using RRC rear spindles and hubs. The landing leg has been replaced with the tongue jack. There's still a long way to go as I've barely started the hard top which will include a modified SII roof and RTT. In stock form the trailer sits 42" to the rail but now sits at 49". It will settle a bit more and should be at 47"- 48" when everything is installed.
Name:	P4260939 (Small).JPG
ID:	93725   Click image for larger version
Name:	P4260938 (Small).JPG
Name:	P4260934 (Small).JPG
ID:	93727   Click image for larger version
Name:	P4260933 (Small).JPG
Name:	P4260931 (Small).JPG
ID:	93729   Click image for larger version
Name:	P4260930 (Small).JPG
Name:	P4260929 (Small).JPG
ID:	93731   Click image for larger version
Name:	P4260936 (Small).JPG
Old April 27th, 2014, 08:29 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Looking great Mark. You even got the garage cleaned out....kinda. I should be down there in a couple of weeks if you need a hand before a run to Marios.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old April 27th, 2014, 10:23 AM
ezzzzzzz
Mark Garrenton
Sounds good, Rick. Yeah, I cleaned out (sorta) the lift bay to get my 240Z out and the daughter's Accord in for much needed exhaust and suspension service. I'm going to get serious over the next few days and purge a load of crap into the scrap metal trailer or trash bins (I never think of you, Robert). It's frustrating having to step over every damn thing trying to work out there.
Old May 4th, 2014, 10:47 PM
ezzzzzzz
Mark Garrenton
I made a little headway this over the last few days. Hindered by a car show my Z club put on, and failed starter in my 240Z and fitting a rebuild L28 into my good friend's street/track 280Z. Here are a few pictures of the trailer's drop gate installed and the Series roof cut up and being shrunk for the hardtop.
Name:	P5020945 (Small).JPG
ID:	94230   Click image for larger version
Name:	P5020946 (Small).JPG
Name:	P5020948 (Small).JPG
ID:	94232   Click image for larger version
Name:	P5020949 (Small).JPG
Name:	P5020950 (Small).JPG
ID:	94234   Click image for larger version
Name:	P5020951 (Small).JPG
Name:	P5020947 (Small).JPG
Old May 5th, 2014, 11:45 AM
what is that tool in the first picture ?
Old May 5th, 2014, 11:56 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Am down sizing myself, although I have a longer road to travel before I am free at last.
RDavisinVA
Old May 5th, 2014, 12:32 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
die grinder...
Old May 5th, 2014, 12:48 PM
ezzzzzzz
Mark Garrenton
Yep, die grinder. I used it to cut the heads off the solid rivets and separate the spot welds holding the roof rib to roof panel.
Old May 5th, 2014, 01:19 PM
looks beefy as hell compared to mine
Old May 5th, 2014, 02:27 PM
Mark, you need my pneumatic rivet squeezer.
Old May 5th, 2014, 02:44 PM
ezzzzzzz
Mark Garrenton
That would be great. I've got a manual rivet tool with about 3" throat depth and a variety of dies. There are only about 150 rivets I need to set.
Old May 5th, 2014, 03:13 PM
I have one you can borrow as well as long as you promise not to hit it with a hammer like needle did
Old June 3rd, 2014, 07:03 AM
ezzzzzzz
Mark Garrenton
The hardtop is still in progress but the trailer has been mostly completed and used this past week for a trip to First Landing State Park in Va Beach. The interior has been glass beaded, acid etched and Line-X coated. Even with the RTT up over 6' the trailer tows like a dream at 70+.
Name:	P6030963 (Small).JPG
ID:	96188   Click image for larger version
Name:	P6030961 (Small).JPG
Name:	P6030965 (Small).JPG
ID:	96190   Click image for larger version
Name:	P6030964 (Small).JPG
Name:	P6030962 (Small).JPG
ID:	96192   Click image for larger version
Name:	P5290956 (Small).JPG
Name:	P5290957 (Small).JPG
Old June 3rd, 2014, 07:40 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Looks great Mark! Nice work. You shopould have moved the tent a little higher so Doug and I can walk under it....lol...
Glad to see you have it to a state where you can use it. There are events coming...so get ready.
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old June 3rd, 2014, 07:56 AM
Mark is that heat plumbed into the tent in that last picture ? I have one of those 120v heat pump units 12kbtu, and never thought of using it for camping.
Old June 3rd, 2014, 08:14 AM
Real differences between your trailer and the M416.
Thanks for the great shots!
Old June 3rd, 2014, 08:25 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I'm betting some kind of drink delivery system......hey its Mark we are talking about here.....
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old June 3rd, 2014, 08:37 AM
Have you seen some of the elaborate shower rigs he has ? Never forget the first "all you need is a tank, a pump, and a heat exchanger on your engine and you let the water recirculate until the whole tank is the temp you want " talk. The man has skills.
Old June 3rd, 2014, 08:44 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I'll bet one of those brown-water drinks that it's A/C.
Rent my
Old June 3rd, 2014, 08:53 AM
ezzzzzzz
Mark Garrenton
Jeff wins anything stuffed animal from the top row. It's A/C and will run on a single Honda EU2000. I wish it had heat as an option and will be looking for such a beast. My only concern in a primitive setting would be if the dual EU2000's would be up to the task. There's also the Pelonis disk heater that I believe would work just fine hanging from the top frame of the tent.
cd
Modified M101CDN with drop gate and hard top ezzzzzzz Smaller Projects 8 April 2nd, 2014 09:26 AM
Military Trailers, M101CDN Tom Fitzgerald For Sale - Vehicles 14 July 21st, 2010 01:33 PM
Pics of the 110 coming along nicely Stmpede Truck Build-up's & Restores 34 March 19th, 2009 08:25 PM
RECO: Trail for newbie along CA coast reaper99999 Trips, Trails and Events 5 April 28th, 2006 01:25 AM
Oh, so THAT was the problem all along Hans Misc. Chit-Chat 8 May 2nd, 2005 03:03 AM
