LS schedule 40 exhaust manifolds - Defender Source
Old January 19th, 2016, 12:44 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Thought I'd start a separate thread for the construction of a pair of exhaust manifolds for my Gen III LS install. After reviewing all the available options and not wanting to end up spending $ on shipping manifolds back & forwards, will be making a set from schedule 40 weld ell's and some 1/2" flanges.
Using 1.5" primaries, and 2" collector it'll drop out to the system with 2.25" V-band couplings.
Here's a pic of a turbo manifold that's similar to what I want to end up with.... but not so shiny
Old January 19th, 2016, 01:26 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Something a bit closer, mine will have the 2" elbow where the straight section is and the right two primaries dropping into the elbow. A 45 degree bend on the bottom of the 90 will have the V-band clamp sitting horizontal just in front of the clutch slave cylinder.
Well, that's the theory
Old January 20th, 2016, 01:10 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Ordered a set of mild steel flanges from CBR Performance, nice thing about these is there counter bored to suit the OD of 1.5" sch'd 10/40 weld els
Old January 21st, 2016, 09:50 AM
Landy_Andy's Avatar
Landy_Andy
Andy
And some 2.25" stainless self-aligning V-band couplers plus a box of weld els. Just waiting now till they all turn up.... I hate waiting
Old January 27th, 2016, 10:08 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got my flanges today... real nice quality
Old January 28th, 2016, 09:16 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Silly photo bucket.... here are the flanges
And with a 1.5" elbow located in the port counter bore
Old January 28th, 2016, 09:45 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Andy:
I have made several custom exhaust manifolds out of schedule 40.
A word of experience, you cannot weld the pieces with a continuous bead and expect the manifold to fit even if you have it clamped down.
The only way to be successful is with "fish scale" welding.
In other words you tack weld the entire assembly and after a test fit, weld one small 1/8" area at a time and then wait for it to completely cool down before the next "fish scale" is welded.
This is best done on a cold winter day when you can weld multi-places, but never more than 1/8" of weld at a time.
Otherwise if you weld the whole thing up with a continuous bead, the warping will prevent the manifold from even coming close to fitting.
Good luck!
RDavisinVA
Old January 29th, 2016, 01:19 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Hi Robert,
That was my plan.... tack up, break down into sub-assemblies, then work my way around all the joints 'ticky tack' fashion with the amps cranked up a bit for good penetration, then assemble the sub-assemblies and final weld up.
Been reading up on the turbo forums and that seems to be the preferred method, even when TIG welded.
The flanges are 1/2" thick but I'll still clamp it all down to a solid plate. Just happen to have a few lengths of scrap grader blade in the back of my work truck that'll do just fine
Old January 31st, 2016, 01:17 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Made a start on the passenger side as it has to clear the starter motor and I wanted to try and use standard bends, worked out just fine with the last 2" being half a 45 degree.... and that leaves me with the other half for the drivers side.
I decided to fully weld it into place to give a solid datum to work off for the rest of the primaries, I didn't want it moving around whilst fitting them up. I think I'll add the other end next to lock it all together and then the centre two. I'm also hoping to be able to squeeze the O2 bung in just above the V bang flange. Keeps it nice and compact and I'll be able to fire it up without the rest of the system being finished
Here is the drivers side being assembled.
Once I have the drivers side in place I can work out the 'Y' pipe and order up some 2.25" bends and a 2 into 1. Think the rest of the system will be 3"
Old February 19th, 2016, 08:11 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got the 2.25" V band flanges & clamps this week, real nice size fit to the pipe
exhaust
New Schedule/New Prices No Limit X JPBrown The Vendors Loft 10 August 19th, 2011 04:38 PM
New 2011 Schedule for No Limit Expeditions JPBrown The Vendors Loft 2 January 8th, 2011 06:49 PM
Preventative Maintenance Schedule hartman Defender Technical Discussions 0 June 25th, 2007 08:31 PM
WTB used exhaust manifolds kellymoe Wanted 1 February 13th, 2004 01:51 PM
