Long Heater hoses on 200TDi - Page 2 - Defender Source
Old February 12th, 2015, 11:10 AM
BlackField's Avatar
BlackField
Oscar
D110
Ahh got it.
I've read that the FPHE should also be positioned flat with the ports facing upward and is best to have the entire thing insulated. Anyone marketing an insulating blanket or just come up with something to retain some extra heat or is it not necessary?
I'm heading out to dig out my brackets and see if I can get the heater mounted on the truck today.
Old February 12th, 2015, 11:30 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Would try it without insulation and then add it if needed.
I think the unit can be mounted in any direction.
Straight fittings are not necessary.
RDavisinVA
Old October 17th, 2015, 11:56 AM
BlackField's Avatar
BlackField
Oscar
D110
What about this? Instead of the T's, I think just plumbed in series would be easier. It shouldn't lose much heat to the main heater.
I just recently replaced my T'Stat but reading back I saw the 195 T'Stat was recommended. Let's see how it works out with the 190 T'Stat.
vs
I'm also now using this little guy as my heater (AC will now be on the left rear without a heater circuit:
Old October 19th, 2015, 07:39 PM
BlackField's Avatar
BlackField
Oscar
D110
here's the AC/ Heater and FPHE bracket:
Old November 23rd, 2015, 05:59 PM
BlackField's Avatar
BlackField
Oscar
D110
200tdi, heater, tdi
97 NAS D90 heater core hoses blenkush Defender Technical Discussions 1 February 16th, 2014 01:50 PM
200tdi heater hoses tomaco1 Defender Technical Discussions 3 August 30th, 2011 01:15 PM
Heater core hoses Cred Defender Technical Discussions 1 November 29th, 2010 09:53 AM
NAS 110 Heater Hoses Stmpede Defender Technical Discussions 3 March 22nd, 2009 06:37 PM
Cutting off heater hoses on 300Tdi... JFD Defender Technical Discussions 4 September 20th, 2006 09:11 PM
