Limb riser mount tabs for new style Hannibal - Defender Source
Old July 26th, 2007, 09:35 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
I previously attached my limb risers to clamps on the "A" piller roll cage hoop. When I installed the Hannibal Rack on my truck I designed a new way to hook my limb risers to the truck. The hannibal has a massive extruded aluminum outter frame. It has a channel in the top of the frame that allows you to drop in a small bolt (inverted) then attach items to the bolts. This is how the rack's side rails atttach to the main frame. Rather than simply drilling a hole through the front of the extrusion and installing an eye bolt I designed and made some simple tabs out of stainless plate, put a slight downward bend (toward the front bumper) and bolted them in. I also had to rebuild my limb risers with 5" of addtional cable length to accomodate the higher height of the rack. Now the younger tree limbs we regularly encounter on some of the tight narrow tracks in the Sierras will slide off of the top of my rack and not put dings in my roof!
ID:	9886   Click image for larger version
ID:	9888   Click image for larger version
Old July 27th, 2007, 09:18 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Len
That looks GREAT hopefully you can sell a few. I know I need to put an order together soon of stuff I need from you.
Now back to beating my paint guy to get some panels back for the project.
Cheers
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 27th, 2007, 09:56 AM
LenB's Avatar
LenB
Len Bruffett
Thanks for the complement. I guess I could offer the tabs as well as additional stansions that support the side rails ( as I made to provide equipment attachment points). My rack came from AB - via ebemotors. The rack is great - it is super lightweight (90 lbs), is super strong, and has a very low profile to allow me into the tight trails we frequent. I have sourced some 5-bar tread plate out of LA so my next project for the rack is to put together (probably a 3 panel sectional) floor. Even though my original plans of mounting it on SD Safari rack supports craped out it is still going to work great. Last week I carried my sons standard sized bed over to his house - it dropped right onto the rack (with the rails attached) like it was made for it! I may not leave the side rails on the rack (for even a lower profile) but they have come in handy for additional feel good security.
Len
mount, nib
Rear light mount bracket four bolt mount riser thing-a-ma-bob evilfij Wanted 14 June 5th, 2009 06:11 PM
Work Lamp mount on new Hannibal Rack LenB Smaller Projects 0 July 10th, 2007 11:51 PM
WIng top shovel mount parts needed Cyborg Wanted 0 March 8th, 2006 11:12 AM
hannibal help? =) scubadanster Misc. Chit-Chat 2 March 9th, 2005 11:24 AM
Limb Riser Fabrication Peter Defender Technical Discussions 2 October 21st, 2003 10:34 PM
