Limb Riser Installation - Page 2 - Defender Source
Old September 28th, 2013, 10:57 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
The Camel trophy D110s have spring loaded limb raisers. The purpose of the springs is to take up the initial shock of the strike instead of transferring the force directly to the wire mounts.
When I made up a set I went to West Marine and used sail boat rigging stainless steel wires & fittings.
These are old low quality pictures but the spring is located at the bottom on the limb riser wires:
TeriAnn
Old September 28th, 2013, 11:18 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I've seen similar setups with the spring. I went wheeling last weekend and must have ripped up four trees...it didn't stress out my risers as far as i could tell, and I did a thorough inspection. I was curious on how taught the cables should be...mine are tight and they worked fine. The springs seem like a good idea but I'm not sure...
Old September 28th, 2013, 11:29 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
In theory that sounds great but in practice I have found they don't do much of anything. Those particular draw-springs are weak & sloppy. I bough a set but ended up returning them. There shouldn't be too much "shock" to speak of unless you're driving through thick brush at high speeds. The thin flexible branches usually absorb most of the impact anyway.
Originally Posted by TeriAnn View Post
The Camel trophy D110s have spring loaded limb raisers. The purpose of the springs is to take up the initial shock of the strike instead of transferring the force directly to the wire mounts. When I made up a set I went to West Marine and used sail boat rigging stainless steel wires & fittings. These are old low quality pictures but the spring is located at the bottom on the limb riser wires:
Old September 28th, 2013, 01:01 PM
maleger
Marc-Andre Leger
I made mine with a drying line and some cable splices. I replace the font screws of the 1/4 plate protector with a eye bolt and put the other end on the roll cage. I used a cable tentionner to tighten up the whole thing and some grip tite on the screwa to keep them tight. If you have to tool to compress the cable ties, the most expensive thing is the cable tentionner (Home Depot). Costs about 10$ to do. A lot cheaper than a windshield.
installation
Arb Limb Riser Tabs Manimal Smaller Projects 15 July 1st, 2010 09:40 PM
Limb riser mount tabs for new style Hannibal LenB Smaller Projects 2 July 27th, 2007 09:56 AM
Home Made Limb Raisers saber6 Defender Technical Discussions 7 January 31st, 2006 02:50 PM
Limb risers Cyborg Defender Technical Discussions 7 April 27th, 2004 08:12 PM
Limb Riser Fabrication Peter Defender Technical Discussions 2 October 21st, 2003 10:34 PM
