Lifting transmission - Defender Source
Old April 29th, 2009, 04:55 PM
seaswood
Diesel
Does any one know if it is possible to lift the transmission lifting from the center point of the transmission and both sides will lift?
I ask since lifting from the center point the drivers side comes up but the passengers side just sits there & that is where the axle is not that should matter. changing mounts, broken muffler hanger etc.
Manual transmission Lt77 mounting bolts loose on both sides.
Old April 29th, 2009, 05:00 PM
I'm pretty confused by your question, but I'll try to ask the appropriate questions to clarify-
Are you just trying to move the trans to swap out the mounts?
Do you still have the transfer case attached?
What exactly is this "center point" you are talking about?
Are you actually "lifting" i.e you've taken the trans tunnel/floor out, or are you "lifting" by jacking it from below?
Pix would really help someone answer this question better.
Old April 29th, 2009, 05:29 PM
support the trans with a jack and remove the brackets bolted to the frame instead
Old April 29th, 2009, 06:43 PM
seaswood
Diesel
That was my plan except the pass side was not lifting so as not to unbolt something that seems to still have a load on it for som reason.
Old April 29th, 2009, 08:45 PM
Make sure you have removed all the bell housing bolts. Use your hand to feel all the way around if needed - sounds like you might not have gotten them all.
Then do what Doug suggests. If it's all unbolted, it should just start coming down with you as you lower the jack.
hth
charles
Old April 29th, 2009, 10:21 PM
Did you remove the inspection plate thing at the bottom of the bellhousing.
Old April 29th, 2009, 10:23 PM
huck1974's Avatar
huck1974
shane cates
94 d90
The first time I pulled mine it required some extra effort with the pry bar. Make sure you didnt forget to disconnect any wires above.
If you are just trying to replace mounts then I don't quite understand your question as they should unbolt from the frame quite easily. Do you have an impact, 3' prybar, big hammer, can jack and 2x4s to spread the frame for the crossmember?
Maybe I just don't know what you are trying to do. Can you be specific as to what you are doing?
And hay
And I love you too
Old April 30th, 2009, 06:41 AM
seaswood
Diesel
Just trying to get transmission off mounts to change them no more.
The transfer case side does not seem to come up while the drivers side is up almost an inch.
Just enough to get load off the mounts.
Yes I could unbolt mounts but if one side is not lifting not sure how much weight will be
therewhen I pull bolts.
Old April 30th, 2009, 09:31 AM
Still not following you. If you want to change the mounts, then put a jack under it and just lift until you have pressure - it doesn't need to lift. Then remove the 3 bolts that go through the frame, the 4 that go into the transmission (if you can't access them, do them after the bottom section of the mount is out) and the bottom mount nut. The mount will just fall out in 2 pieces. Replace the mount and repeat on the other side.
Old April 30th, 2009, 09:52 AM
seaswood
Diesel
Thanks will try that when the mounts come in.
This all started when I found a broken muffler hanger that attaches to the drivers side transmission mount, the rubber of the mount was compressed enough that the top rear bolt could not line up properly to catch a thread & the thru bolt bottom nut rusted threads.
Other side is fine figured I would try to do both sides.
Old April 30th, 2009, 08:52 PM
huck1974's Avatar
huck1974
shane cates
94 d90
even if you took them out with no jack it is bolted to the motor and will drop some but it is not going to fall out or anything. You will be fine.
And hay
And I love you too
Old April 30th, 2009, 10:47 PM
Ah, no. It will tilt a good bit and the fan will hit the shroud in front risking damage.
Old May 1st, 2009, 05:13 PM
seaswood
Diesel
Risking damage well that was the risk every time u touch one of these things it seems
As long as body parts stay safe.[img]file:///Users/craig/Desktop/photos2009/IMGP2664.JPG[/img]
Old May 1st, 2009, 10:25 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I was attempting to make a point.
I guess I should also say that the first time I pulled mine, I was fighting it so bad that the jack slipped out from under it and no damage was done. It moves a whole lot easier after the first time.
And hay
And I love you too
Old May 24th, 2009, 12:42 PM
seaswood
Diesel
Follow up on Transmission mounts seems lifting the mount is the best was specially with the transfer case side.
Thanks any one have advice on changing engine mounts 2.5 na diesel?
transmission
ZF4HP22 transmission question..... kiphartzell Defender Technical Discussions 9 December 28th, 2005 09:11 AM
Lifting engine and transmission together?? cbass Defender Technical Discussions 5 November 7th, 2005 06:23 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
