License Plate LED Lamp & Rear Fog Lamp Install - Page 2 - Defender Source
Old December 5th, 2007, 10:42 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
LOL, I can't believe they specifically require a dummy light on the dash & specify the color for it too!
Old December 5th, 2007, 03:46 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Welcome to California. I have a work truck I brought in to my local shop to have a smog done. Truck passed no problem and all was good. I did not see I was supposed to go to a smog only station and not a repair station. Even though it passed with no problem I now have to go to a state referee(a one hour trip) to have the truck looked at before I go to a smog only station. All this because it wen through the wrong smog station even though it passed. Oh well, at least it doesnt snow here and it is blue sky and 68 degrees right now and a 3 bedroom 2 bath house that needs work is 1.5 million. I love it here. MIke
Old December 7th, 2007, 08:47 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Originally Posted by LenB
Thanks for the info and compliments - I had a feeling that's where it should be located - since the rear fog lamp on our audi is on the drivers side. - I was just taking advantage of the nice little bracket on the bumper. I should probably fab up a small simple bracket and attach it to the base of my rear ladder mount off of the rear cross member.
Problem with the ladder mount is you'll inevitably kick it by accident. I initially had mine on a bracket on the ladder. I decided the best place for me was on the body.
http://www.pbase.com/dmarchand/image...519/medium.jpg
http://www.vtxs.org/tvtx/day2/images/_w5w4905.jpg
The dash light is an easy one.
Old December 7th, 2007, 09:34 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
pull the reverse light move it to the other side & mount the fog where the reverse light was
I have not had coffee yet>>>>>>>>
Old December 16th, 2007, 08:54 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
I am Compliant!
I have moved my rear fog lamp to the left side of the truck - It turns out that there is a single factory square nut with M10 threads welded to the bottom of the rear cross member of my '97 - just where I wanted to put the light. I made a simple bracket and bolted it in place. The lamps sits up just underneath the step bumper. it is funny I did not see this mount point before - I would have used it in the first place.
Thanks for the recommendation -I use to have my reverse / work lamp mounted directly above my license plate. The current location is actually good for what I use it for. I do some night mountian bike riding and having the lamp up higher is easier on the eyes when I load the bike up on a rack. Also I get moderately better shadow and depth perseption when reversing at night off road. When the light was lower it was hard to tell if a drop in the road was 5 inches or several hundred feet because the shadow was cast directly in my line of site. ( I have had to make a 2 or 3 point turn in pitch black conditions on more than one of the switchbacks I've gone though in the eastern sierras) With the light up high, shadows are cast downward rather than outward from my line of site.
lamp, license plate
Rear Work Lamp rover4x4 Misc. Chit-Chat 5 February 19th, 2005 12:41 PM
License plate Mike Hippert Misc. Chit-Chat 27 September 16th, 2004 04:07 PM
Rear (Red) fog lamp? dmarchand Misc. Chit-Chat 24 August 4th, 2004 10:53 AM
Diamond plate rear panel protectors Burke For Sale - Parts 3 June 25th, 2004 01:07 PM
