license plate - Defender Source
Old March 14th, 2013, 03:42 PM
redway77's Avatar
redway77
Beatrix
110
license plate
ok so the second to last owner of my 110 had a love affair with velcro. He/she stuck the license plate on with velcro, among other odds and ends that are on this truck with the sticky stuff.
so my problem is how is every one putting their license plate on? I have holes already drilled( i did not do this found the hole when i removed the velcro) but the holes are too wide for my license plate thus i will have to drill holes in the plate and figure out what size fastener to get it all together. and im thinking if i do use screws i will have to line the back of the plate with something to keep it from vibrating the paint off and causing a problem.
so should i just use velcro again and hope someone does not steal my tag ( i would not put it past some retard to do this in Tampa).
Suggestions?
Old March 14th, 2013, 03:46 PM
Front or back?
Old March 14th, 2013, 03:48 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Assuming it's the front.....Go to an auto parts store and get a plastic bracket like this, http://www.autozone.com/autozone/par...=439392_0_2826_
Fasten the bracket to the bumper and attach the plate to the bracket.
1997 P38 4.6
1998 P38 4.0
2011 LR4
rivet nuts
Old March 14th, 2013, 03:49 PM
redway77's Avatar
redway77
Beatrix
110
Its on the Back. I dont have to worry about front tags here in FL
Old March 14th, 2013, 03:56 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
Like mentioned, go to the auto parts store and get a little plastic bracket. It's worked fine on my RoW truck
Old March 14th, 2013, 04:05 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Pop Rivet.
so my problem is how is every one putting their license plate on? Suggestions?
I have used aluminum sealed pop rivets for the past 25 years... with stainless washers.
They leave very small holes, are easy to install, and very easy to remove with a portable drill.
RDavisinVA
Old March 14th, 2013, 04:06 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
3M heavy duty double sided tape.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old March 14th, 2013, 04:07 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I bought some nice stainless nuts/bolts with a special security head that looks like a Torx head with a dimple in the middle.
It's not rocket science at all, but it does help to have an extra set of hands as you will find yourself woring under and inside while somebody could be outside tightening/holding.
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
well you have a NON US car trying to fit a USA style plate. =)
if there are no holes - the panel has either has always "not been drilled and license has been plate stuck on" - or - "its a new panel and no one has drilled holes"
i think the offical term is "nut certs" then you can screw a plate on.
Old March 14th, 2013, 04:09 PM
redway77's Avatar
redway77
Beatrix
110
the rivets seem like a good idea, im guessing i would need to find someone with a riveter (spelling right?). what about rubbing on the paint? did you have that problem?
Old March 14th, 2013, 04:16 PM
Since there are no holes, I would go with heavy duty industrial tape or stick with the velcro. YOLO. On a NAS truck, there are four rivnuts, which work fine if you use the plastic screws so the screws don't seize in the holes.
Old March 14th, 2013, 04:21 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Never if you use the 1/8" and install the rivets properly.
We have a rivet gun the works off air pressure, so the installs are always tight.
If you do a poor hand riviter job, then you get just that.
RDavisinVA
Old March 15th, 2013, 09:39 PM
NikosF
Nick
1995 NAS D-90
What size rivnuts?
I need to put my new plate on, and the allen bolt is just turning and turning, so I'm going to have to cut them off.
What size rivnuts and bolts were originally used?
Old March 15th, 2013, 09:50 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
lol YOLO reference.
Old March 15th, 2013, 11:52 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Size...
Originally Posted by NikosF View Post
What size rivnuts?
If my memory serves us accurately, think they were 6mm rivnuts from the factory and 1/4 - 20 from a US dealer.
Have no affection for those things... again pop rivets are a better choice.
The jig is up.
RDavisinVA
Old March 16th, 2013, 12:24 AM
If your rivnut spins, you can access it from behind and hold it with a pair of vice grips. Once the old screw is out, you can JB weld the backside to make it not spin and use the plastic screws (all the ones I have seen are metric and I hoarded enough of them). Ideally you want to replace the rivnut, but how rarely you change the plate, my solution works.
Old March 16th, 2013, 12:25 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
You don't need a special tool to instal a rivnut. A nut, bolt, washer, piece of flat stock and a couple of spanners and your fine. Google search "installing a rivnut without a tool" and your golden.
Old March 16th, 2013, 09:11 AM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
ron - if you do not want to continue to use old warn out plastic "bolts" anymore - i get a package from "belmetric" every couple of months! =) [bel metric - ralph or tony - 800.544.1624] i think there are 50 in a plastic bag. i get the 6 x 16 size.
keith humphreys
keith . humphreys @ me . com
617 . 308 . 4100
Old April 8th, 2013, 08:35 PM
Explorer0863's Avatar
Explorer0863
Tony Q
1957 Series I V8
Did you install the plate? I have a rivet gun and rivets of different sizes. I also have a license plate frame that, if you want it, is yours free. I'm in Longwood.
license plate
License Plate Help Part 2 excanuk Misc. Chit-Chat 6 January 11th, 2013 04:49 PM
Front License Plate Mount Hinckley423 Defender Technical Discussions 24 December 27th, 2011 09:19 AM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
Personalized License Plate Jon_Winningham Misc. Chit-Chat 38 May 12th, 2007 11:57 PM
License plate Mike Hippert Misc. Chit-Chat 27 September 16th, 2004 04:07 PM
» Defender Registry
Pancho
LPP
Blu
Cred
Add your Defender
