LED Tail Light Installation - Defender Source
Old January 21st, 2014, 12:25 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
My RN LED tail lights should be waiting at my door tonight when I get home, and I plan to install them tomorrow.
Can someone point me in the direction of what I may need in order to get these things working?
I assume I'll need relays, and I'm hoping they are available at the local parts store.
I have searched the forum, but there's so much chatter, I can't find my answer.
Thanks!
Old January 21st, 2014, 12:36 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Did you get the RN connector kit? PLK289CK.
http://www.roversnorth.com/ProductDe...1995-ON&key=it
Also you may need the WIPAC smart load device to regulate the blinking rate; SLD12V
http://www.roversnorth.com/ProductDe...LED-12V&key=it
Old January 21st, 2014, 12:41 PM
Thanks!
buy the relay from RN. Install per my post in this page.
http://www.defendersource.com/forum/...ad.php?t=36519
------ Follow up post added January 21st, 2014 12:45 PM ------
you shouldn't need the stuff that thewap linked above. I believe they come pre-wired from RoversNorth so they should be plug and play. The resistors should also not be necessary unless you're insalling LED turn signals up front, in which case, install the resistors there (if needed).
Old January 21st, 2014, 02:12 PM
WD90's Avatar
WD90
Dan
I'm hoping the local joints will have a suitable relay so that I can get these things working tomorrow.
Old January 21st, 2014, 02:18 PM
My Wipac LEDs came with an adjustable relay. You can set the flash rate to whatever you like.
Old January 21st, 2014, 02:24 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
This is what you want right here - http://www.roversnorth.com/ProductDe...LED6000&type=0
Adjustable flasher unit/relay.
Old January 21st, 2014, 02:35 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Zack,
I have LED bulbs in the front and standard bulbs in the rear. Will this relay work to slow down my flash rate? It is twice as fast now with the front LEDs. If so, I'll place my order today.
Old January 21st, 2014, 02:36 PM
Originally Posted by down_shift View Post
Zack,
Yes. It is adjustable to give whatever flash rate you would like.
Old January 21st, 2014, 02:40 PM
down_shift's Avatar
down_shift
Russell
Order placed. Thanks.
Old January 21st, 2014, 04:21 PM
WD90's Avatar
WD90
Dan
Is there anything at Advanced Auto/Auto Zone/Pep Boys that can hold me over until I can order the adjustable relay?
I have no rear lights right now
Old January 21st, 2014, 04:24 PM
The stock relay will work. The lights will just flash faster than before.
Old January 21st, 2014, 04:25 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
From what I understand if you install them with your regular relay they will still work but the flashers will be a much faster rate.
Old January 21st, 2014, 04:54 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Isn't the fast flashing supposed to indicate a broken bulb?
Old January 21st, 2014, 04:56 PM
yes ... it occurs because the load is reduced ... LED's have less load hence high flash rate!
Old January 21st, 2014, 05:01 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I know
Old March 18th, 2014, 09:25 AM
down_shift's Avatar
down_shift
Russell
Zack, wanted to circle back to say the adjustable flasher relay works great. Thanks.
ht, installation
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
Need tail light lenses and Jerry can holders Cyborg Wanted 2 January 13th, 2006 12:20 PM
Rear lamp guards (tail light) mod4b Wanted 1 August 2nd, 2005 05:06 PM
tail light guards ronward Wanted 3 April 5th, 2004 11:14 AM
