Later style lamp Assembly Upgrade - Defender Source
Join the Defender Source Community Today
Old October 15th, 2016, 02:34 PM
airbalancer's Avatar
airbalancer
1988 RHD 110 5 Door
I changed out my indicator, brake and sidelights to the later style plug in type last weekend in an effort to clean up some wiring issues I was having. The lights require a larger opening and I found that a Greenlee 1-3/4" Radio Chassis Punch works a treat. To line up the punch I took one of the old lights and snipped a notch into it, then spun it with a sharpie giving me a circle about the same size as the punch. Then its just a matter of lining up the punch with your mark.
Cheers
ID:	159840   Click image for larger version
ID:	159842   Click image for larger version
Old October 15th, 2016, 07:04 PM
Tarheeld
Bill
1985 110
Ha! Wish you had posted this last week. I ended up hand cutting mine which was a PITA.
Old October 15th, 2016, 07:56 PM
terryjm1's Avatar
terryjm1
Terry
1988 Land Rover Santana & 98 D1 TDI
I was considering using a large step drill bit. This does seem more precise.
Terry
Old October 15th, 2016, 08:11 PM
Either make a near perfect circle.
assembly, lamp
Later Style Series Radiator Shroud 61rover Wanted 0 April 23rd, 2013 09:46 PM
New Headrest for later models CDeWan For Sale - Parts 0 January 19th, 2011 12:22 PM
later model front door skins ibjettin For Sale - Parts 4 November 17th, 2010 11:00 PM
2002 and later d90 diesel90 Defender Technical Discussions 4 November 11th, 2004 04:13 PM
