Kickdown cable? - Defender Source
Old April 25th, 2014, 09:21 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Kickdown cable?
Can anyone take a picture of the kickdown cable attachment on 300tdi throttle linkage?
Apparently I'm missing something...
Rent my
Old April 26th, 2014, 09:04 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
nobody running a zf?
Rent my
Old April 26th, 2014, 09:29 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I am, so you want on the IP where the kickdown cable connects?
Old April 26th, 2014, 10:56 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah, that'd be great.
Thanks Neill.
So, I think I have 2 issues.
There is nowhere for the kickdown cable to connect; and the cable is several inches to short to reach anyway!
Is there a different cable part #?
Rent my
Old April 26th, 2014, 11:35 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Ashcrofts sells them here : http://www.ashcroft-transmissions.co...-brackets.html
The actual part numbers are err4897 and err1604. One of the brackets goes near the injector lines in the back and the other sits on top of the plate that the throttle cable is hooked too here is a pic of mine.
ID:	93662   Click image for larger version
Old April 26th, 2014, 11:37 AM
navydevildoc
Neill Thornton
OK, this should get you the right idea.
Two pictures... one is the forward top side of the IP that shows the bracket that bolts on to connect the cable.
Second picture is the cable bracket behind the IP that holds the cable sheath/jacket. Sorry for the crappy pic but it's a blind shot and I can't tell the damn phone to focus on the bracket instead of those hoses.
Maybe this makes more sense now?
Name:	2014-04-26 08.30.53.jpg
ID:	93664   Click image for larger version
Name:	2014-04-26 08.32.26.jpg
Old April 26th, 2014, 11:45 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Those are great shots, guys.
Thanks!
Rent my
Old April 26th, 2014, 04:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Mine...
Rent my
Old April 27th, 2014, 08:46 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
OK, I need the bracketry obviously.
And, no way my cable is long enough to reach---
Rent my
Old April 28th, 2014, 06:39 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Well....sheeit.
Ashcroft lists the 200/300 cable as 1200mm long.
The V8 cable is 980mm long...
Looks like the only solution is to change the cable---frack!
Anybody changed the kickdown cable on a Tdi ZF before in situ?
Rent my
Old April 28th, 2014, 06:45 PM
Well....sheeit.
Will says changing a kick down cable is no big deal. I haven't had to do one.
Old June 2nd, 2014, 01:26 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Hey Peter,
Finally got my brackets-Ashcroft came through but they were backordered.
If possible could you get me a shot where the cable anchor mounts near the back of the IP?
One of your pictures almost shows it but missed the bolt.
I'm guessing its that small bolt on the back side....
Rent my
Old June 2nd, 2014, 01:34 PM
jafir's Avatar
jafir
Jafir Elkurd
This might help:
http://discoweb.org/forums/showthrea...light=kickdown
Old June 2nd, 2014, 01:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah Jafir, I've read the gospel according to PT and kickdown cables.
I have to change the cable on mine(uggghh) but I also have to get the brackets mounted.
This was a non-auto motor originally.
The top bracket is pretty easy; and I think I can see where the rear/anchor bracket mounts...just want to confirm.
Then I'll tackle changing the cable.
Rent my
Old June 3rd, 2014, 08:35 PM
Broncoduecer
peter
D90
Does this one work?
Old August 18th, 2014, 04:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Thanks for that pic, Peter.
There is also a blank threaded hole right below where your anchor-bracket is mounted-don't know what the thread is...
I finally got my kickdown cable changed--wasn't too bad as the trans was essentially empty.
I would hate to do it on a recently run trans...yuck.
Rent my
Old August 20th, 2014, 06:12 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
http://up.picr.de/18962206va.jpg
Old August 20th, 2014, 08:54 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I ended up using that threaded blank hole...
Rent my
Old August 20th, 2014, 09:18 PM
Broncoduecer
peter
D90
Dang I don't have that one. Looks like good alignment though!
Old August 20th, 2014, 09:33 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah, it worked great-cable aims straight to the other bracket.
I was going to use the same bolt in your picture when I saw the hole right below it-and it was threaded!?
Pretty tough to get pics down there; I'm using a Nikon D90 with a 10.5mm fisheye...
Rent my
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
Kickdown cable for 300tdi ZF gearbox Davin Wanted 0 March 2nd, 2013 09:14 AM
Kickdown cable on ZF, DOH! RedRhinoProducts Defender Technical Discussions 0 November 13th, 2004 10:32 AM
Sub woofer cable? wicks Defender Technical Discussions 17 May 18th, 2004 09:51 PM
Installing new kickdown cable...anyone? P1CR Defender Technical Discussions 4 December 19th, 2003 01:15 PM
