KAM Locker install - Defender Source
Old January 17th, 2014, 09:01 PM
discojosh2000's Avatar
discojosh2000
Josh
1995 Black ST
KAM Locker install
I'm going to be installing KAM lockers into my D90. So far we have cut the axles housings and welded the mounting ring. We will see how this goes.
ID:	88042   Click image for larger version
95 D90 Black ST
06 LR3 Black
10 Range Rover
Old January 17th, 2014, 10:01 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
espere un momento....you're doing this?...lol. I'm impressed, are you getting ready for a wheelin expedition? Was going to come down to see you guys this week but I've been hold up with the flu.
Old January 17th, 2014, 10:57 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
What's the advantages to kam over arb or Ashcroft?
Defender 110
Old January 18th, 2014, 12:30 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Ashcroft and ARB are both air-actuated, while the KAM is electronically controlled. You could definitely argue in favor of the KAM in terms of simplicity and reliability due to the fact that it requires fewer components, but the ARB is a proven setup and I don't know that either one has a significant advantage over the other.
All selectable lockers require a 'feed' of sorts from the cabin to the axle housing, be it an air line, wiring, or a cable. The biggest downside with these types of setups is the risk of pinching or breaking your means of controlling the lock/unlock function, which would render the differential useless. Careful routing can negate the risk, but I have seen a handful of failures over the years.
The only real negative I have seen with the ARB is the hassle of potentially leaky fittings at your air compressor and/or tank.
I think it's really a matter of what you prefer and who you'd rather spend your money with. KAM and ARB are both great in my experience, and although I have no firsthand with the Ashcroft, there seem to be a lot of folks out there running them with positive experiences.
Geared Restoration Co.
352-572-3236
Old January 18th, 2014, 03:29 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Having to cut and weld your axle tube seems like a pretty big disadvantage to me.
Unless I'm missing something, there's no going back from that, except to source a new tube. No longer interchangeable with generic LR open diffs if you blow one up in the desert somewhere. Better hope your KAM dealer has them in stock because you won't find a spare at a junkyard.
On the other hand, I love an electric option other than a Toyota axle conversion.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 18th, 2014, 03:53 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by chris snell View Post
Having to cut and weld your axle tube seems like a pretty big disadvantage to me. Unless I'm missing something, there's no going back from that, except to source a new tube. No longer interchangeable with generic LR open diffs if you blow one up in the desert somewhere. Better hope your KAM dealer has them in stock because you won't find a spare at a junkyard. On the other hand, I love an electric option other than a Toyota axle conversion.
Exactly why I went Ashcroft front and rear!
Semper Fi!
Old January 18th, 2014, 05:54 AM
Ash's Avatar
Ash
Ash Heller
Oh man, I cursed the last set of Toyota E-lockers I did.
The install is a bit labor intensive, but you can still run a standard open 3rd if you happen to grenade a diff. The modification made to the housing is on the diff cover side, to allow clearance for the solenoid and locking dog, and the way the differential mounts into the housing remains unchanged. It really isn't much more work than installing a sewer cap diff cover, which is a pretty popular option these days.
And as cheap as axle housings are, if you ever decide you no longer want it you can pick up a junkyard Disco axle, rebuild, and toss it under the truck at minimal cost.
352-572-3236
Old January 18th, 2014, 07:41 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Someone needs to tell Kam to tone down the marketing,
A big, shiny plate with "KAM" and "DIFF" "LOCK" ?
Yuck.
I'll keep my ARBs.
Rent my
Old January 18th, 2014, 09:50 AM
discojosh2000
Josh
1995 Black ST
Bill we are trying to plan a trip to Hidden Falls around the first week in Feb.
While this setup is a lot of work and everyone has there personal opinion on what Locker they prefer. I do like the look of the removable diff covers and the idea of a e-locker. I decided to give KAM a try. Hope to get both axles done next week. (KAM e-locker, 4:10 R&P, HD front and rear axles)
95 D90 Black ST
06 LR3 Black
10 Range Rover
Old January 18th, 2014, 12:16 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by discojosh2000 View Post
Bill we are trying to plan a trip to Hidden Falls around the first week in Feb. While this setup is a lot of work and everyone has there personal opinion on what Locker they prefer. I do like the look of the removable diff covers and the idea of a e-locker. I decided to give KAM a try. Hope to get both axles done next week. (KAM e-locker, 4:10 R&P, HD front and rear axles)
I kinda wish these were out when I started buying parts for my front Toy conversion. I like the E-locker as that was one of the main reason I went Toy. And the removable diff cover seems like a really nice option. It seems like a lot less work than a Toy setup (which IMO fabrication wise the Toy setup wasn't bad at all).
Question on the KAM E Locker - can you engage/disengage manually if the power supply is compromised? I can do so on my Toy setup and did for a while when I was street driving it.
Old January 20th, 2014, 02:10 AM
Landy_Andy's Avatar
Landy_Andy
Andy
ARB sells bling covers for Dana axles, besides 10 minutes with a flap disc will take care of that.
-Jeff
Devon 4x4 make a H/D diff cover that's bolted to a weld on ring. There proven in UK hard core off-road events, combined with an ARB or Ashcroft a great combination
Old January 20th, 2014, 11:49 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Linky to D44's cover for info :http://www.devon4x4.com/index.php?pa...mart&Itemid=14
Old January 20th, 2014, 12:11 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Lovely.
A bright red diff cover.
That would look great....on a Jeep.
Of course....I paint my OME shocks black because the yellow is too *bling*.
Rent my
Old January 20th, 2014, 12:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Lovely.
They do them in black too....
Old October 5th, 2016, 10:48 PM
User Name
User
NAS D90 '95
can you show us how you wired this? mine keeps blowing fuses....
Old October 11th, 2016, 11:03 PM
RamblerRob
Rob Apps
1967 series 2a 109 NADA
I'm about to take possession of a rig with a set of these installed front and rear along with all the kam HD axles and all. They are reported to work great but there is a small issue in power draw. They are supposed to draw 45amps to preload the spring and only 5amps to stay engaged. In this case they are continuing to draw high amps while engaged.
Old October 11th, 2016, 11:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Honestly not sure why anyone would run these, besides to be different. They don't work better, they aren't easier, they aren't more reliable, they require more modification, they're not cheaper, etc. There's no reason.....
Old October 11th, 2016, 11:52 PM
User Name
User
NAS D90 '95
Maybe that's why we keep blowing fuses... not sure. it's been a pain in the a$$. i now think there's a short to ground in the main harness so, i'm going to run through it all and see.
I'm curious to see where you got the 45 amps number from?? the directions call for a 30-35 amp fuse (yea, clear as mud) and it's funny because it calls for a 70 amp resisted relay....
Maybe that's the problem I'm having? needs a 45 amp fuse? i've tried 40 and that blew... took a little longer but blew. i'm just worried it will legitimately cause a fire if i try larger fuse and something happens...
------ Follow up post added October 11th, 2016 11:54 PM ------
zack, because at the time of purchase they had the only LSD diff with a combined with a locker option. i'm not sure anyone offers that. that said, i would not get this again if given an opportunity. their customer service is horrible and they wont warranty mine because Allmakes didn't pick up that line when they bought KAM...
Old October 12th, 2016, 01:01 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
People run them because they work. Read some Aussie off road and rally/RAID sites, it is a popular option even in ARB land. Not my cup of tea, anyway.
I personally would lean towards Ashcroft Locker. These guys have been doing Land Rover gearing for about 30 years.
There is also the Detroit option. No, not give up and just move away... Detroit lockers for Salisburys.
KGH - “Stinky LR diesel” Defender Snob
Old October 12th, 2016, 02:14 AM
RamblerRob
Rob Apps
I just recalled the 45 amp figure from conversation with the guy who I'm buying the truck off of or from reading the internet.. could well have been 35 amp. The guy I'm buying off indicated that he had a 35 amp fuse and wasn't having trouble with it blowing.. just that its not meant to keep drawing that high of amps while engaged.
As far as 'why people put them in' I couldn't say. I did look at them when planning my build and wasn't really considering them as they are a bit overkill for what I need and more pricey than i was willing to pay. But given that they come with the truck I'm pretty happy that they are there
ARB locker ready to install 3.5 gears ron For Sale - Parts 11 October 18th, 2012 11:48 AM
Salisbury Detroit locker install how to evilfij Defender Technical Discussions 16 March 23rd, 2009 11:23 AM
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Need ARB locker install manual dave_lucas Defender Technical Discussions 13 December 6th, 2006 11:05 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
