Just got my defender- grinding gears! - Defender Source
Old May 21st, 2008, 06:33 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
I am freaking out a little bit. I just got my defender today & when I switch from 1st to 2nd gear there is a bit of a grind. Any suggestions?
Old May 21st, 2008, 06:57 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
Check the fluid and/or drain and put some Redline MTL in the trans.
Mike Lynch
Old May 21st, 2008, 07:16 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Mine does that too. Just let the RPMs fall below 2000 before you shift and you'll be fine. You can nurse this for a long time. You can always double clutch between 1 and 2 as well.
Some people say that the MTL will remedy this.
Pharmacists believe that you can fix problems with drugs. Surgeons believe you can only fix things with a scalpel. Me, I'm a cutter.
Oh, this post would best be answered in the Looking for help?Post here section. Also try using the search function. It's great and you can generally get an answer in an instant.
Let me answer your next post: Yes, they all clunk like that. The slack in the drivetrain is designed to be there. If yours doesn't, then it's likely something is wrong.
Welcome to Rover life.
-Neil
Old May 21st, 2008, 09:45 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Thanks guys. I will look into this transmission oil. I knew right away that the defender would be a lot rougher than my jeep- & I like it! Please keep the suggestions coming!
Old May 22nd, 2008, 12:14 AM
Welcome!
Replace your oil cooler lines if they haven't been done. Search here to find why. Or keep a couple skewers and a pack of marsh mallows on board for the occasion.
charles
Old May 22nd, 2008, 06:20 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Hey David,
Some guys here are just too sarcastic, it really gets to me too
Seriously though, show us your new rig! Many converts here too, you're in good company. Post a pic in the Misc Chat and say "Hey".
Old May 22nd, 2008, 02:09 PM
Just time it. My red one the second synchro was worn and I just timed it. I believe the new owner is doing the same. It has been four years or so . . . plus whatever time the guy I bought it from put on it.
Old June 15th, 2008, 10:26 AM
Redline MTL.
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Defender 90 Scoop For Sale - Vehicles 0 December 10th, 2005 11:46 PM
1994 Red Defender 90 for sale BrianConway321 For Sale - Vehicles 5 February 22nd, 2005 09:27 PM
