Isuzu 4JB1-T in a 110 - Defender Source
Old March 29th, 2014, 10:01 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Initial install and motor mount fabrication of a 4JB1-t into a 110 with a R380 Stumpy.
Used the large Mercedes hydraulic filled motor mounts that absorb most all the vibrations.
ID:	92005   Click image for larger version
ID:	92007   Click image for larger version
ID:	92009   Click image for larger version
ID:	92013   Click image for larger version
ID:	92015   Click image for larger version
RDavisinVA
Old March 29th, 2014, 10:07 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Motor mount prototype work:
Note the mounts bolt righ onto the existing frame mounts for the 2.25, 2.5.
That way the conversion is bolt in without any cutting or welding.
Later this summer we will make the same type of mount for the 200TDI and might even do the 300TDI this winter.
ID:	92018   Click image for larger version
ID:	92020   Click image for larger version
ID:	92022   Click image for larger version
ID:	92024   Click image for larger version
RDavisinVA
Old March 29th, 2014, 11:01 AM
87 D110 (Ruby)
Nice work Robert...
Old March 29th, 2014, 11:07 AM
You are living on the edge. I pull the bonnet and the radiator and breakfast when r&r'ing an engine.
Old March 29th, 2014, 01:48 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Please do the 300tdi! I beeg you
Old March 29th, 2014, 04:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Very cool Robert!
Any changes needed to the pan?
What clutch setup are you running on this and are you running the same clutch setup on the OM617 rig?
Where do you source these motors? I did a quick google search and couldn't find much about them. I very well could be searching on the wrong parameters tho.
Those Merc motor mounts are going to start going up in price if you make them for the 2.5/200/300's!
Old August 11th, 2014, 08:07 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Finally got a few hours trading time among a GM build and the 4JB1-T conversion.
Got the motor mounts and high output alternator installed.
The custom mounts bolt right to the original 2.25/2.5 4 cylinder frame mounts on the bottom with the top bolting directly to the engine.
In between is the big Mercedes hydraulic mount.
So there is no cutting and or welding to install, just a direct bolt in.
The engine looks high enough to clear any and all front end movement even with another 1/2" of spacer shims.
Anything worth doing is worth overdoing...
ID:	100515   Click image for larger version
ID:	100517   Click image for larger version
RDavisinVA
Old August 11th, 2014, 08:38 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Planing on doing the 200TDI this fall and hope to get to the 300TDI bolt in mounts this winter. Both with the big Mercedes hydraulic mounts.
RDavisinVA
Old August 11th, 2014, 08:53 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'd take a few sets
Old August 11th, 2014, 09:19 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Old August 11th, 2014, 09:25 AM
This is great.
Old August 11th, 2014, 09:54 AM
Well @ least you mention you are building my gm engine as an aside.......
Old August 11th, 2014, 10:30 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looks good.
are these blocks similar to the 4BD1? IE could these motor mounts work with the 4bd1? You'd shut a few of those guys on Pirate up, haha.
Old August 11th, 2014, 10:35 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by don View Post
Looks good.
NO.
Completely different.
Made for an SUV engine not a big delivery truck.
RDavisinVA
Old September 9th, 2014, 11:26 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Intercooler hoses are in air cleaner installed.
Tyler was home and turned up the fuel to the sweet spot and added a waste gate bleed off to get more boost.
Fastest 110 I have ever driven.
ID:	102625   Click image for larger version
ID:	102627   Click image for larger version
ID:	102629   Click image for larger version
ID:	102631   Click image for larger version
RDavisinVA
Old September 10th, 2014, 09:23 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Sweet - cool to hear its a strong setup.
Where do you source your IC pipes from? I am a while out but eventually want to do that setup on the Merc.
Old September 10th, 2014, 09:35 AM
cxracing.com has the best prices on turbo plumbing parts. I ordered all my stuff from them. They carry universal fit intercoolers, ally and stainless pipe, silicone elbows and reducers, and the t-bolt clamps.
Old September 10th, 2014, 09:49 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Put Me down for a set for 200Tdi LR90 and possible set for 200Tdi D1
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 10th, 2014, 09:50 AM
Nicely done. One of these days I'm going to spend an afternoon teaching you how to make up a tidy wiring harness.
Old September 10th, 2014, 10:33 AM
What kind of mpg does that isuzu deliver in a 110?
Mark Kellgren
KM4BOR
1993 Defender 110 2.8 Isuzu Diesel eliatodd For Sale - Vehicles 16 April 23rd, 2012 08:37 PM
Isuzu powered 110 grnrvrs The Flea Market 2 February 23rd, 2012 11:19 PM
Isuzu 4JB1 conversion question wolfieroc Truck Build-up's & Restores 2 September 2nd, 2008 01:59 PM
Isuzu 2.8L 4JB1 T wanted wolfieroc Wanted 2 August 15th, 2008 01:12 PM
