Iron Goat Dash with CB - Defender Source
Old July 28th, 2008, 10:01 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I haven't wired the switches yet as you can see. But I was pretty proud of myself for getting the oil pressure gauge hooked up. Not a big deal, but sometimes the smallest things turn out to be the biggest nightmare on a Defender.
I think the CB fits in there pretty nicely though. I installed the console slightly off-center to the left, making it closer to the driver, and it lines up directly with the fuse box cover below.
I like the way it turned out. I plan on having the ARB switches, air pump, front lights, rear light, and then something else.
Just thought I would like to share the pics . .
ID:	14533   Click image for larger version
ID:	14535   Click image for larger version
Old July 28th, 2008, 10:17 AM
I like it, it looks really good!
Old July 28th, 2008, 04:53 PM
Very nice. How did you mount the CB? Do you have some kind of DIN cradle, or is there a U bracket just suspeding it through the hole?
Old July 28th, 2008, 08:36 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
You can sort of see it in the picture, but there are tabs that are on both sides of the CB. Basically, I think it is the metal where the opening is bent back to the sides to create the hole. I drilled a hole on both sides that lined up with the CB mounting holes and used the thumb screws that came with the CB. I bought the CB specifically because it would fill out the opening.
Name:	dash frm marvp2507.jpg
Old July 28th, 2008, 09:40 PM
Got it. I had an Iron Goat before I sold it to get the MudUK, so I know where you're coming from. thanks.
Old July 29th, 2008, 02:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Greg
This looks great. I have wondered and this goes for even the Land Rover updated dash, do you have to worry about the back of the radio getting wet as it covers a bit of the vents?
Old July 29th, 2008, 02:33 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Hey Barry,
I know the new Defenders no longer have the vents in the front. They still have the lines of the vent but the bulkhead is one piece with no vent holes. I am considering sealing my driver's side vent completely with silicone or something as I will probably never use it. Good point though regarding the water.
Old July 29th, 2008, 02:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Has anyone else thought of this? I was just looking at ECR http://eastcoastrover.com/159.html
Wonder what this guy will do other than not want to get it wet.
Old July 29th, 2008, 08:18 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
That's a sweet truck.
Old July 29th, 2008, 08:41 PM
Both the Iron Goat and MudUK dashes have back panels that extend almost the full length up in their mounting space. The iron goat is full, the MUDUK is about 80%, leaving maybe 2-3 vent holes max, which are easily siliconed shut if you desire.
Old July 29th, 2008, 11:03 PM
Abrooks's Avatar
Abrooks
Tony Brooks
nice job, Greg! Which CB is it?
Old July 30th, 2008, 12:45 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Hey Tony,
It is the Cobra 18 WX ST II.
http://www.solunar.com/Cobra-18-WX-S...dio-P2621.aspx
Greg
Old July 30th, 2008, 04:23 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Why would you worry about the vents? Just put the updated seals in them and they won't leak.
Old July 30th, 2008, 05:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
what if you have them open?
Old July 30th, 2008, 11:03 PM
Yeah I use my vents and don't want to restrict the air flow with the dash. I dig that new style console and vent setup though.
But I hadn't given too much thought to water coming in from the back side. Definitely not installing my mud uk dash in the ST for now...
Old July 31st, 2008, 12:09 AM
give you an lt95 for it
Old July 31st, 2008, 08:30 AM
LOL. It's slated to go into Janey for now. Will let you know if that changes
dash
Iron Goat Dash CDeWan Defender Technical Discussions 16 September 3rd, 2013 10:30 AM
Iron Goat Dash AggieD90 For Sale - Parts 3 January 14th, 2009 10:59 AM
Iron Goat Door Panels CDeWan The Flea Market 0 September 22nd, 2008 02:01 PM
Iron Goat Dash Overlander For Sale - Parts 5 February 21st, 2008 11:54 AM
Iron Goat dash? JackW Defender Technical Discussions 12 September 29th, 2007 06:55 PM
