Installing carpet in RHD 110 - Defender Source
Old August 24th, 2016, 10:57 AM
rjwellman
Robbie
I'm about to begin the process of insulating/sound dampening and then adding new carpet into my 1991 RHD 200tdi 110. I want to carpet the entire thing, including the cargo area. I'm having a hard time figuring out what carpets are available and what I need to be looking to buy.
Any advice?
Old August 24th, 2016, 11:18 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Have you checked out Exmoor Trim's options yet? Probably would not hurt to swing by an upholster shop. These boxes are probably pretty straightforward for them. Might want to make it all removable in case water gets in and you need to dry out.
Are you trying to bring the noise level down?
Old August 24th, 2016, 11:22 AM
Unless the truck is garaged and never driven in rain, you will probably be happier with rubber mats. A cut down NAS d-90 mat in the back and removal genuine mats in front is a good option.
Old August 24th, 2016, 11:27 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Here is a video detailing the install of the Exmoor carpeting. I think I am going to have a local upholstery shop do my front area carpeting rather then using this kit.
Old August 24th, 2016, 12:10 PM
rjwellman
Robbie
Yes, I am trying to bring down the noise level a bit. My thought was to do something like dynamat or similar to help with insulation and sound deadening. I have looked at the Exmoor stuff. I sent an email to get clarification from them (I guess it went straight to Rovers North here in the US) on what I'd need and response has been a little slow.
It will be garage-kept. I'll definitely have rubber mats on top of the carpet and in the cargo area.
Old August 24th, 2016, 12:14 PM
Exmoor trim does a rubber sound deadening mat system. Carpet is a bad idea.
Old August 24th, 2016, 12:23 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Voice of reason...
We've installed and uninstalled most of the major options out there and the only thing I currently recommend for front seat in-cabin effectiveness and long term functionality is the moulded matting.
Do not affix deadening materials to panels - the same goes for carpets. Eventually water will work it's way under the covering and then corrosion starts. This goes for bedliner and powedercoating as well. Sound and heat are best attend to with layered solutions that are non-permanent. And avoid anything at low points that will hold moisture...
Old August 24th, 2016, 12:54 PM
1of40's Avatar
1of40
1of40
My front mat is the original one-piece that goes from door to door. I use a rubber floor mat in the footwells too. I've covered both sides of the trans tunnel with a self adhesive insulation material just like dynamat and I stuffed the void around the tcase shifter with heavy foam. In the back I'm still running the original thin factory floor runner in the cargo area and the middle row floor. They're factory original so to be honest I should roll them up and save them before they crack or split.
ID:	156322   Click image for larger version
Old August 24th, 2016, 01:01 PM
AdamSanta85
91' D90 200TDI
You take out the carpet out of your 97 SW?
Old August 24th, 2016, 01:27 PM
1of40's Avatar
1of40
1of40
No, kept the carpet in the 90. I'm referring to a tdi 110.
110, rhd
For Sale NAS 110 carpet Himalaya For Sale - Parts 5 August 13th, 2014 04:21 PM
Install Exmoor Carpet 110? Jbullis Smaller Projects 0 September 25th, 2013 10:10 PM
NAS 110 Carpet color cabell Misc. Chit-Chat 5 February 22nd, 2013 12:26 PM
110 carpet kits Tyler Wirken Defender Technical Discussions 12 April 21st, 2011 12:31 PM
110 carpet that goes behind fuse box bjf For Sale - Parts 6 September 25th, 2010 06:11 PM
