Install Puma Dashboard on 300 TDI without installing a new Gearbox - Defender Source
Old October 3rd, 2015, 11:51 PM
DininduInduwara
Dinindu Perera
2002/300 TDI
Exclamation Install Puma Dashboard on 300 TDI without installing a new Gearbox
Hey I just bought a 2002 300 TDI Defender and I'm getting into modding it. I quite like the Puma dashboard, but I've been hearing that you need to install a Discovery gearbox so that the gear leaver will not knock on the Puma dash. Question is whether I can keep the original Defender gearbox but install the Puma dash? Thanks in advance
Old October 4th, 2015, 12:04 AM
Not without some seriously custom fabrication. How good are your fab skills?
Old October 4th, 2015, 12:05 AM
DininduInduwara
Dinindu Perera
2002/300 TDI
Will that be cheaper than getting a new gearbox?
Old October 4th, 2015, 12:06 AM
I don't think you understand what you are attempting to do.
If you don't understand what an mt82 is, I don't think you're ready to do this.
Old October 4th, 2015, 12:08 AM
Old October 4th, 2015, 01:47 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Read this:
http://www.defendersource.com/forum/...ead-65026.html
A 2002 should have been a td5, but I guess anything could happen out there in the real Rest Of World! ;-)
Quick fix? Torch/Bend the snot out of it!
Is it possible that Uncle D's advice regarding the shifter angle being "adjustable to a driver's stature/comfortable reach for the old lt77, could be applicable to the shifter lever of the newer R380 or newest mt82?
http://www.defendersource.com/forum/...gle-54619.html
Old October 4th, 2015, 02:21 AM
D90Overkill
David Frank
1995 ST #2615
Try to see the differences in interference from the lower dash panel as you:
want to go from this: ( image 1 )
to this: ( image 2 )
or by going disco gearbox, you'll have mating issues as evidenced by ( image 3 )
http://forums.lr4x4.com/index.php?showtopic=67131
So it isn't going to happen without some kind of major adjustment to the shifter lever or fabrication on your part. Note the pitch at the base of the mt82 of the puma? Perhaps you could completely modify/fab the throw of your existing R380 with a slick shift and a good bend?
But then, after you've figured all that out, you'll have a heck of a job swapping all the electrical for the new gauges.
Either way, good luck, but I wouldn't attempt it. Be happy with your td5 style, or sell it and buy a puma. No reason you can't in Sri Lanka.
ID:	131492   Click image for larger version
Old October 4th, 2015, 03:36 AM
Land Rover continued to build 300tdi Defenders for military users and certain overseas markets long after introducing the TD5.
Old October 4th, 2015, 03:46 AM
D90Overkill
David Frank
1995 ST #2615
Agh! Figured it was something like that. Well, good for us! Volume, volume, volume! ;-)
Old October 5th, 2015, 06:48 PM
Defender1987
Gunther
87 lr 90
maybe you could install an 300tdi auto box and put the auto shifter in place like the nas one ?
300 tdi, dash, dashboard, tdi
LT 95 gearbox..do I have to remove gearbox from truck to replace reverse idler shaft? Ncmike Series Technical Discussions 3 April 13th, 2014 03:33 PM
300 TDI Engine and R380 gearbox for sale k4rovers For Sale - Parts 3 January 13th, 2009 12:39 AM
300 tdi engine and 5 speed gearbox k4rovers For Sale - Parts 0 September 19th, 2008 10:55 AM
300 TDI Engine and 5 speed gearbox for sale k4rovers For Sale - Parts 0 August 5th, 2008 07:27 PM
300 TDI engine and 5 speed gearbox $5000 k4rovers For Sale - Parts 2 April 18th, 2008 01:48 PM
