Husky 10 and steering - Defender Source
Old November 8th, 2008, 10:04 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
My weekend project began yesterday with some steering mods. I got ride of the factory tie rod and made a new one with 1.5 inch dom tubing, .250 wall. I used 1 ton tie rods and retappered the holes to fit the MUCH larger tie rod end.
Also on the agenda was installing a new winch. A buddy of mine had a Husky 10 he wasn't going to use so I bought it off of him in July and haven't had time to get it on yet. I pulled it out of the box and started the process of mounting this monster on my bumper...
Name:	Copy of IMG_1222.JPG
ID:	16209   Click image for larger version
Name:	IMG_1228 - Copy.JPG
Old November 26th, 2008, 08:29 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Nice mod on the steering. That's the first time I've seen that done on a coiler.
I used the same stuff, 1 ton Tie Rod ends and 1.5" 1/4 wall tubing, on my 109 for both the drag link and tie rod, but that was in conjunction with making my own hi steer set up on my Salisbury front axle.
Old December 13th, 2008, 04:56 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
What is the diameter of the bolt on the 1 ton TRE?? What did you drill up to on the knuckle (is it tapered)?
Do you think that this may weaken the knuckle attachment itself, ie instead of rod failing you break the knuckle at the attachment??
I want to do similar but using Heim joints but would need to drill up to 3/4"......are you drilling to 3/4"??
Badger Tops, 110 and 90 Cages and Miscellanies Stuff ron For Sale - Parts 63 March 10th, 2009 07:42 PM
Leaky power steering box Lindy Defender Technical Discussions 15 January 26th, 2009 04:31 PM
Steering question d901560 Defender Technical Discussions 3 April 11th, 2006 08:39 AM
Nathan Hindman chrisvonc Defender Owners 0 July 5th, 2004 09:09 PM
