How to fab or buy crimped galvanized hoop set tubing - Defender Source
Old May 10th, 2016, 06:07 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Hey folks, I've got a soft top, 3 door 110 with the Exmoor top and hoop set.
This week, I finally finished the install of a roll bar to regain my shoulder belt ability. I COULD bend the forward horizontal hoop bar around the roll bar, but that's ineligent, and the roll bar actually has tabs to accept these crimped galvanized tubes.
I'd like to go from the one long roll hoop bar, to two shorter ones that go from the B pillar bar, to the roll bar, and then the roll bar, to the C pillar bar.
This is the precise setup I'm looking for:
So the question is:
  1. Does anyone know where to buy custom lengths of crimped galvanized tubing?
    OR
  2. Does anyone have advice on how to crimp your own tubing?
Since I'm going to remove the 2-3" distance of the width of the roll bar, I could probably actually make the two lengths from the existing hoop but cutting and crimping, but I'd love advice on how best to pull this off without making something TOO janky.
Thanks!
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old May 12th, 2016, 03:52 AM
Google bar brace tarp or bar brace canopy?
Old May 12th, 2016, 08:05 AM
Naplm00
Matthew
I just cut my long pieces with a hack saw then flattened in a vise and drilled a hole.
I have the exact setup pictured above and it looks perfect.
I hit the cut bar with cold galvanizing spray
Edit: I didn't like shoulder belts so I also cut off the roll bar belt attachment points. I then Installed lap belts and had the ability to leave the roll Bar on when my hardtop truck cap was in place
Old May 14th, 2016, 07:25 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I think I'd squish the flat bits in the vise...but between some wood blocks just to limit damage to galvy surface. If you wanted to get fancy you could rout (e?) a channel in the wood so they'd all end up the same.
Old May 24th, 2016, 08:25 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Originally Posted by Naplm00 View Post
I just cut my long pieces with a hack saw then flattened in a vise and drilled a hole. I have the exact setup pictured above and it looks perfect. I hit the cut bar with cold galvanizing spray Edit: I didn't like shoulder belts so I also cut off the roll bar belt attachment points. I then Installed lap belts and had the ability to leave the roll Bar on when my hardtop truck cap was in place
Giving this a go tonight. Got the pieces cut, but my vice is just too shitty. Heading to a buddy's with a normal, old school big ole vice.
Any advice on how to somewhat match the offset of the factory ends?
Old May 24th, 2016, 08:32 AM
Those things are smushed in a large hydraulic press that whacks 'em in a die that holds the pipe shape. Just flattening the end in a vise won't give you the same result, but it will give you a result.
Old May 24th, 2016, 09:03 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
yeah, that'll just have to do until I can source some factory made pieces
Old May 24th, 2016, 09:06 AM
Naplm00
Matthew
Just stick a flat piece of scrap on the side that you want offset the squish away.
It works but obviously isn't for purists
Old May 24th, 2016, 09:29 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Buy a few Legnths of 1" conduit from home depot and crimp (vice) a few ends until you are happy with the result. Much cheaper than potentially ruining the nice factory bars.
Old May 24th, 2016, 10:13 AM
Naplm00
Matthew
Not a bad idea actually
Old May 24th, 2016, 10:18 AM
JohnsD90's Avatar
JohnsD90
I made these exact pieces for my 88" hoopset using conduit. I could have done a better job, but you never see the pieces anyway when you have a top on.
Old May 26th, 2016, 12:22 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
I'll post pics soon, but in the end, I chopped the piece down to two correct lengths, then cut a notch into the still round end that perfectly slips onto the roll bar tab. Drilling holes in them this weekend to slide a bolt through, but on first pass they fit perfectly and are snug just with pressure (and a zip tie for peace of mind).
hoop
Source for Silicone Vacuum Hose/Tubing? MUDSUX Defender Technical Discussions 9 May 28th, 2010 10:34 PM
Defogger Duct Tubing Baldewin For Sale - Parts 0 April 2nd, 2010 05:46 PM
Welding thin aluminum air condintioning tubing? Davis Defender Technical Discussions 5 January 9th, 2010 06:38 PM
OEM Rear Speaker Parts, Oil Cooler Lines, Snorkel tubing Wolf Fabrication For Sale - Parts 7 April 30th, 2008 04:02 PM
3" Diameter Snorkel Tubing Wolf Fabrication For Sale - Parts 3 March 6th, 2008 09:28 AM
