Hotrod style gearstick. - Defender Source
Old November 10th, 2012, 06:19 AM
Cube II's Avatar
Cube II
Michele
1997 D90
I need to modify/fabricate a new gearstick to clear my CB radio.
I've been thinking about adding a bend here and there and extending the rod,
hotrod style.
but I'd rather have a whole new one made from scratch.
I don't know what the insert is for and if it's best to be kept for optimal operation.
I thought it has something to do with the "balance" of the stick, but I can't see how...
Anybody know?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old November 10th, 2012, 07:29 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Damper?
Michele
D90 VNTdi
[O]===[O]
Old November 10th, 2012, 07:34 AM
Hmm probably to allow for LHD v rhd gearsticks.
Figure out where to needs to go heat and bend.
Old November 10th, 2012, 07:43 AM
Cube II's Avatar
Cube II
Michele
1997 D90
From a thread found online it seems to be a damper, as my fabricator hinted this morning...it's rubber cushioned inside.
I can't see the need for a damper
I will probably chop the whole stick off the engagement ring and put the new one in place.
Then switch gears with plenty of love (which I already do).
Michele
D90 VNTdi
[O]===[O]
Old November 10th, 2012, 09:37 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I always thought it was the modern replacement for that roll of duct tape that is normal in Series trucks
Old November 10th, 2012, 09:56 AM
Cube II's Avatar
Cube II
Michele
1997 D90
LOL!
Hey Keith!
Michele
D90 VNTdi
[O]===[O]
Old November 10th, 2012, 01:13 PM
carlosz's Avatar
carlosz
Carlos
it is a damper, so when gears are scratched and or vibrations exist, they don't transfer to the operators hand, it is very common on big rigs.. trust me if you scratch a gear or a gear jumps you are glad that damper is there, other wise you will have a very sore wrist for a while...
Old November 10th, 2012, 02:16 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Bending and extending a stock one to keep it would probably mean a bodge job...I don't know...thanks for the infos!
Michele
D90 VNTdi
[O]===[O]
Old February 18th, 2013, 03:09 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Some progress this evening
Name:	2013-02-18 18.49.58.jpg
Michele
D90 VNTdi
[O]===[O]
Old March 1st, 2013, 02:44 PM
Cube II's Avatar
Cube II
Michele
1997 D90
1 Ton press action...et voilą
Name:	2013-02-18 18.52.05.jpg
Michele
D90 VNTdi
[O]===[O]
Old March 1st, 2013, 03:12 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Lookin good man. Looks a bit like an old series stick or maybe one off of an old Chevy SM420 or SM465
Old March 1st, 2013, 03:22 PM
Needs a bloodshot eyeball as a handle.
Old March 1st, 2013, 03:31 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Thanks Dan!
It's similar to the Series stick (at least at a glance at my 109"), but with an extra bend right before the handle.
I rattlecan sprayed it this evening (pure hotrod style, eh), will install it tomorrow.
It took a couple of adjustments tho, first it was too closed angled, and covered the underdrive red knob...heated with a torch and opened too much later, bent again and finally got it right
It looks good and works well, I love it.
Eyeball handle, that would be stylish
Michele
D90 VNTdi
[O]===[O]
Old March 6th, 2013, 03:48 PM
Cube II's Avatar
Cube II
Michele
1997 D90
After the 1st road test I can say it works very well
It may look a tad funky but I can now slot 4 gears in with 2 fingers without leaving the steering wheel
Michele
D90 VNTdi
[O]===[O]
FS: BFG 265/75R16 A/T (old style tread) fleabus For Sale - Parts 2 March 15th, 2006 10:36 AM
If you need some style while hunting WCURoverD90 Misc. Chit-Chat 4 February 7th, 2006 12:34 AM
new style door hinge $ mattdh Defender Technical Discussions 2 December 4th, 2005 01:27 AM
Basket Style Roof Rack boshea Defender Technical Discussions 1 January 16th, 2005 03:12 PM
Vents for 94 style AC evilfij Wanted 3 June 3rd, 2004 11:43 PM
