Home Made Rear Bumper/Receiver Hitch/Tire Carrier - Defender Source
Old March 8th, 2015, 05:09 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I started this bumper quite a while ago and didn't finish the tire carrier portion all the way until recently. I wanted a tire carrier, receiver hitch for light duty towing, and some rear bumper protection that somewhat resembled a NAS step bumper but was a little different. This is what I came up with. It is made from 3/16" steel flat stock and .120 wall DOM tubing. It utilizes only factory drilled holes on my Richards galv chassis. I also utilized the tubular holes built into the crossmember like the NAS bumper. The pivot is a heavy duty spindle with angular wheel bearings made by 4x4 Labs. It has a spring loaded locking pin behind the tire carrier that holds the carrier open at approx 90 degrees, with a "J" hook that locks the pin into place. The pivot that attaches to the tailgate uses large greasable suspension bushings. There is a rubber (suspension) bump stop that keeps it secure when closed and keeps it from rattling. I made it heavy duty so I can add a spare mounted bike rack if necessary. I sort of designed it as I built it and changed a few things during the process so there are a few things I would do different on the next one. Anyway, here are some pics.
ID:	115543   Click image for larger version
ID:	115545   Click image for larger version
ID:	115547   Click image for larger version
ID:	115549   Click image for larger version
ID:	115551   Click image for larger version
Old March 8th, 2015, 05:20 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Really nice job Macker
I like how it has the NAS look but has a bunch more clearance. I am guessing there are no rattles from the tire carrier with that big old bearing setup!
Old March 8th, 2015, 05:26 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Thanks don. Partially why I chose the big bearing spindle was so I didn't have to drill into my shiny tub. Had to drill into the tailgate but that's not as big of a deal.
Old March 8th, 2015, 06:24 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
"Where's the beef?" Right there, baby!!! Nice work! That looks so tough with, amazingly enough, enough homage to look stock!
Old March 8th, 2015, 06:50 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Beautiful work.
1985 Land Rover 110 3-door ST
Old March 8th, 2015, 08:34 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Great build, this is def a needed design, very impressive work
Old March 8th, 2015, 09:39 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Had to add another post after looking at the pics again. Lots of very nice details. Like how the plates have threads/nuts welded on and the bolt goes in from the frame out. Or how the beads go all the way around so less chance of corrosion. Not needing to drill into the body with that spindle yet the tire mount ties into the tailgate so there is no latch needed. And that built in bumpstop.
I can't imagine how long that bumper took to fabricate.
Old March 8th, 2015, 10:23 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Thanks guys. It did take a lot of time to build. But partially because I would do something and it wouldn't be quite right so I would re-do it. It would go a whole lot faster the next time if I wanted to build another one now that I figured it out.
Old March 8th, 2015, 10:38 PM
how does your lift gate latch ?
Old March 8th, 2015, 10:41 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
It doesn't actually "latch", it's held shut by the tailgate like a NAS POE truck. I replicated the POE style plate that attaches to the liftgate
Old March 8th, 2015, 10:43 PM
D90Overkill
David Frank
1995 ST #2615
Oh. Cool. Slick all around. Someone here is eventually going to ask you how much you would charge to make them one! I'll take the under on a week. I hope it won't be me, but I make no promises ;-) Again, great job!
Old March 10th, 2015, 09:18 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Macker, looks really good man. I have to meet you and check out your River the next time I am in SoCal.
Old March 10th, 2015, 09:42 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Impressive design and execution. Your new tub thanks you.
Hard to believe this started out as a SIII. Nice work all around.
Old March 11th, 2015, 09:26 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
very nice work !
__________________________________________________
shoefnik wrote: "It’s funny how that moral line you draw for modifying your Rover changes as your needs change."
bumper, carrier, hitch, ht, tire, tire carrier
home made rock sliders Gunmaker Smaller Projects 7 September 29th, 2013 08:22 PM
Front Hitch Receiver willtillery For Sale - Parts 4 April 2nd, 2007 06:56 PM
Home Made Limb Raisers saber6 Defender Technical Discussions 7 January 31st, 2006 02:50 PM
Home made rear bumper! TwisteD90 Defender Technical Discussions 21 May 12th, 2005 09:27 PM
home-made rock sliders Chris Cox Misc. Chit-Chat 8 May 7th, 2004 05:57 PM
