help with brake light - Defender Source
Old February 19th, 2008, 09:37 PM
defender1844
Amit Likhyani
I am the latest to get screwed over by Safari Gard. I bought one of their rear tire carriers and never received the brake light kit or rear door handle. I got the main assembly and was able to get a bump stop and correct spacers and bolts out of them so I almost feel lucky. I am going to dispute the brake light adapter with my credit card company as it was a separate transaction.
Anyway, has anyone fabbed their own brake light kit? Any suggestions?
They were supposed to send an extension on the rear door handle so you can open the rear door with the gas cans in place. Is there way to put a new handle on the cylinder as opposed to drilling into the factory one since I am on my own anyway for this piece?
Old February 20th, 2008, 09:02 AM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
i think that is basically all you do is extend the existing, maybe with a little bend. i had on on one of my 90's and i think that is all it is. something you can adapt pretty easily. good luck.
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old February 20th, 2008, 10:28 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
I was thinking of fabbing up a 3rd brake light kit to replace the factory units on a ST. I was going to look into DOT approved LEDs. If you find one of the appropriate size (probably close to the length of the stock unit) and show me where you want to install it I can likely build you a nice case/mounting bracket.
Go to my products section of my americandirtroads.com site to see the type of hardware I fabricate.
brake, ht
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
