Heater Box Rebuild - Defender Source
Old December 16th, 2017, 03:35 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
Heater Box Rebuild
I know we have many heater box rebuild threads here. What I'm trying to figure out is what did you use as replacement thin foam inside the box on the flaps?
Old December 19th, 2017, 01:26 PM
Mendicant
An adhesive-backed foam. I got some from Wurth one time and some from McMaster. Not as big a fan of the stuff sold at big box stores but it will work. Try to get closed-cell to avoid water retention.
Old December 24th, 2017, 09:52 AM
scooter's Avatar
scooter
scott
1986 110 Country
I am working on my heater box as well. This is the material i am going to use from amazon. Best price i could find.
Old December 24th, 2017, 12:36 PM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
I have not rebuilt my heater box so I cannot confirm this works for that purpose, but I have used Dynaliner for other purposes in my truck. It's closed cell so it does not soak up water and it is heat resistant (made for use under the hood). I've personally cut out a square, put it on a food scale, soaked it in water, and weighed it again. It does NOT absorb water and after 1 year under the hood it looks as good as the day I put it in. The adhesive seems to work well but if you wanted to be extra sure it stays in place grab a can of 3M spray adhesive from Amazon or any big box home improvement store.
Dynaliner 1/8" thick from Amazon link
If you can't fix it with a hammer and a wrench, then you probably have an electrical problem.
Old January 6th, 2018, 06:22 PM
scooter's Avatar
scooter
scott
1986 110 Country
I used the foam from amazon and it looks good. Maybe a little thicker next time to take up more gaps due to bent sheet metal. Otherwise good fit up and easy to cut to size.
heater, rebuild
Heater Box for a 1997 NAS Defender SW Mike Defender Defender Technical Discussions 3 December 15th, 2017 10:53 PM
Defender Heater Box Re-Build jncilliers Defender Technical Discussions 5 March 24th, 2017 03:06 PM
The "Increase your heater output" thread Overlander Defender Technical Discussions 25 February 28th, 2012 06:42 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
